Help..Dansk oem to SSI's hitting bumper fit on 80 sc..
When I installed my engine back (3.0 SSI's 2 in 1 out dansk OEM new mounts)
The left engine bolt won't go all the way in the crossmember it's about 1/8 short. Noticed the Dansk tail pipe hitting my lower valance and bumper, loosened all the Muffler bolts and shaved a little bit on the valance and it's still hitting. I did searched And some says the OEM tail pipe is meant for the early bumpers and some didn't have a problem at all. What em I missing? Solutions I'm thinking.. 1. Is the Dansk Oem diff to Sport is just the tail pipe? 60mm vs 70mm. Or it's internal as well? I'm asking if I can just cut the tail pipe and Weld a 70mm pipe to gain the clearance. ( would that be same as sport). 2. Should I put a 1/8 or 1/4" spacers between the body mount and crossmember To lower the engine a little to gain muffler clearance? Or make a relief cut under the bumper but then the muffler is so tucked in there. 3. I don't really want to buck up for the Dansk sport if I don't have to ( my oem Dansk Is brand new). What you guys think? I'm very curious on the Dansk sport and oem difference besides the tail pipe though. I'm sure someone knows. Thanks Ogi Here's a pic after install you can see the left side is lower, that's when the bolts are Torque to specs.
Here's another pic
![]() You can see the left is a tad lower. |
Maybe it's a 73 and earlier muffler.
Slow old car
I had this same problem- paid a muffler shop to cut/move/weld the tip down and out.
If you search here, it’s a common problem. I don’t know why pelican can’t figure out which muffler is for which car. I even ordered mine on the phone with a sales rep to be sure, after reading the threads about poor fitment
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
Gotta order a '74 version for impact bumper cars with SSIs.
I have a Monty on my '69/3.0 and the tailpipe angles upward a bit and catches water, as well as looks a bit off. Going to cut and reposition it when I get a sec. Must have been a monday muffler, 'cause usually they're fine.
Crotchety Old Bastard
That's why our part number ends with an "E" for Early 911. MKM27 for the impact bumper cars, MKM27E for the early cars. KISS logic.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Hi Syncro
As many of you guys know , I work for JP group / SSI and we just had a look at your problem and what we can see is that you got the 92,210 that is for ealier cars ( now we dont know who advise you , or you bought it used etc ) But What you need is the model 92,211 !!! oem nr 91111102501 or Jp part nr 1620607900 that will fit spot on we are also here on Pelican under the tread "SSI goes online" or you can follow us on instagram SSIEXHAUST for latest news or if you got a question Hope it helps Stay safe Marek |
Thanks Marek.. yup I think I got the wrong muff..
I'll just do what east bay suggested. Cheers! |
RETIRED
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
