Designer King
Check out posts 7 and 8 in this thread. Looks like the line to the lower part of the WUR on a 75-77 should be connected to the top port on the side of the throttle body. The top of the WUR connects to the lower port on the throttle body.
https://www.google.com/url?sa=i&url=http%3A%2F%2Fforums.pelicanparts.com%2Fporsche-911-technical-forum%2F336661-2-7-cis-wur-dizzy-vacuum-lines-routing.html&psig=AOvVaw272UdJnTbCcBI2iZxUyQCt&ust=1621127336945000&source=images&cd=vfe&ved=0CAIQjRxqFwoTCPiXw4rAyvACFQAAAAAdAAAAABAr
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 05-14-2021 at 06:16 PM.. |
If he didn't have this problem prior to the WUR rebuild but has it now, working backwards the WUR would be the prime suspect as well. ASIDE: On my neighbors MFI system air-leak last night I was able to help find the leak because I was a little more generous with the starting fluid (I brought the can after he ran out). We tried using propane gas but could not get the same results, I think both our canisters were low on pressure. EDIT: What's up with all the dead-end links guys?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Junk Car Aficionado
1977 Porsche 924 (2003-2005) 2003 Porsche 911 (2017-2019) 1975 Porsche 911 S (2019-present) |
Junk Car Aficionado
My car has been running poorly ever since I bought it. It seems to run the same with the WUR vacuum line hooked up or not and with the electrical connection hooked up or not. I checked the voltage on the connection going to the WUR and it had roughly 12volts. Maybe I should check the cold start valve connection next? I just got my fuel pressure tester kit and I plan to check the fuel pressures next. Maybe then it will help me figure out what is wrong. One thing I never really thought much of is that while my engine has an issue with a steady idle. The actual RPM gauge seems to bounce around much more than and not in sync with what the engine is doing. Thought it might be the voltage regulator but the volts going to the battery stay steady when the car is running. I was thinking maybe this has to do something with my non adjusted points? I am supposed to get a Petronix pointless ignition system today, I'll put that on and see if that does anything. Cheers, Alex
Junk Car Aficionado
I'll give anything a try!
I checked the Porsche Technical specifications booklet for my year and model and it says between 2% to 2.5% I have a Gunson gas analyzer and it is really hard to get a good reading because the outside air is supposed to measure 2% but the reading is always changing, by a lot! I think I have it between 2% and 2.5% roughly, I will try to adjust it to run a little richer and see what that does. It seems like my engine runs rough either way. Sometimes I can adjust the idle screw and the mixture to get the engine to have a steady idle around 1000rpms but then I go drive it around and it won't run steady anymore. So frustrating! I am really starting to wonder why people say the CIS system is more reliable than carbs... ![]() Cheers, Alex:
A bouncing Tach is an indicator of a bad alternator or voltage regulator .
Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Junk Car Aficionado
How to Test?
What is the best way to check the voltage regulator and alternator?
Agfours
If you suspect fuel delivery, be sure to check fuel filter. I just posted about a clogged fuel (with pics), and I experienced poor idle, rough running, and the like. Easy to do, and as was pointed out to me by others, if you haven't done it within a year, it's overdue anyway.
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
Designer King
Are you sure the points are correctly adjusted? A bouncing tach can be a sign of bad or badly adjusted points.
Have you checked the number on the WUR against the charts I posted, and have you checked to see that your fuel and control pressures are in spec? After checking that all ignition parts are in spec, and verifying for no vac leaks, then getting the fuel pressures verified is the next step. You will need a fuel gauge with correct fittings for CIS to do this. If you can't do this, at least get the people who redid your WUR to send you the fuel and control pressure numbers so you can compare them to the chart. Have you tried Souk's field test for fuel setting w/o a meter? If you press up on your fuel metering flap just slightly while the engine is idling and the revs rise, you can go richer. A too lean mix can cause an irregular idle. While you have the diz out to install the Pertronix, check the axial (up and down) play of the shaft. Too much play can reportedly cause an irregular idle.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 05-19-2021 at 06:45 AM.. |
Check you ignition distributor for smooth movement? If the weights are stuck, you can experience erratic and intermittent idle and running issues.
Easy to check with a timing light and does cost you anything other than time. |
Designer King
I have read somewhere that axial play in the shaft is not as critical when using a Pertronix as it is with points, although I can't verify this.
I recently had an irregular idle speed and, after running through the checks I mentioned above, I replaced my worn plugs and gapped them to .042 (with Pertronix) rather than the .028 spec for points equipped engines. I also replaced the O ring seals around the fuel injectors, and richened my mixture a little, and the idle is now rock steady.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 05-19-2021 at 08:17 AM.. |
What is the timing set to?
How did you set it? The timing advance should be smooth as the rpms increase. When was the ignition distributor cleaned and lubed? You can pull it and dunk it in a gallon of penetrating oil for a couple of days and see all the crap come out. When the timing is set, then go and set the CO and RPM to spec. You probably have done this already.
Dave K |
