Not enough power going to passenger side low beam
Hello
My passenger side low beam isnt working. Car has the sealed lense/bulb style
Known things
1. Drivers side low beam works
2. Pushing the stalk on the steering wheel forward turns on and leaves on both hi beams
3. Pulling back on the stalk does nothing
4. Both turn signals work
5. Both running lights come on putting the headlight switch in the first position
6. Changing the passenger headlight bulb to a new one didnt help
7. No fuses blown on the panel
8. Tested the leads that the sealed bulb plugs into, drivers side 12 volts with low beam switch on, passengers side 4-6 volts, what happening here?
thanks
1977 911S(c) with an 81 SC engine Anthrazite grey metallic
1979 911SC Coupe in Sky Blue - SOLD
1976 911S Widebody Targa - SOLD
Old 05-12-2021, 11:14 AM
Just had this happen. No visibly blown fuses. Pulled them anyway, cleaned contacts and replaced with new fuses. Worked.
Old 05-12-2021, 11:54 AM
Ill do that right now, thanks!
Old 05-12-2021, 11:59 AM
RETIRED
Joe Bob's Avatar
Do you have an aftermarket relay kit? Good idea for saving the burning up of the stalk and other lighting accessories.
https://www.pelicanparts.com/More_Info/JWST911HLPR.htm?pn=JWST-911-HLPR&msclkid=fd417576a24b139353e515ea8a534836&utm_source=bing&utm_medium=cpc&utm_campaign=Shopping%20Ads%20-%20Porsche&utm_term=4580634170083223&utm_content=Porsche%20Catch%20All
This easy-to-install kit uses factory connections and mounting points. With the relay kit, the electrical current travels straight from the battery to the headlight circuit at the fuse box, greatly reducing the load on the headlight switch and the failure prone column switch. In addition, more power is supplied to the headlights for maximum light output. Maximum 100 watt bulbs recommended.
2012 ML350 3.0 Turbo Diesel
Old 05-12-2021, 12:11 PM
I dont have the kit but i will order, thanks for the info
Also holy moly just cleaning the contacts and replacing the old non blown fuses fixed it!!
Old 05-12-2021, 12:17 PM
throw a pair of H4 bulb assemblies in -- not too expensive -- the Koito headlamps (7" round) are supposed to be the best out there these days -- https://www.danielsternlighting.com/products/products.html#Buy Simple, drop-in replacement for the sealed beam bulbs and a night and day difference from the sealed beam units once properly aimed.
d
Old 05-12-2021, 04:11 PM
I replace tons of fuse that are seriously corroded. Folks don't tend to check them very often. If they look crusty gray, replace them. Give them all a light spray of penetrant for good measure. Keeps the corrosion at bay. Something other that WD, which tends to go away pretty quickly.
206 637 4071
Old 05-12-2021, 06:43 PM
Good point - check fuses for corrosion. Also, install a relay kit for the high and low beams to get the current out of the ignition switch.
Sold: 1989 3.2 coupe, 112k miles
Old 05-13-2021, 08:31 AM
A smudge of dielectric grease on the contact surfaces keeps corrosion at bay.
Sherwood
Old 05-13-2021, 08:04 PM
RETIRED
Joe Bob's Avatar
Personally I shytecanned the plastic fuses and went with the aftermarket style fuses. Our sponsor sells the kit.
Haven't had an issue except for a few overloaded circuits due my ride being a greymarket import and a 3.6 conversion.
I remember back in the day when my DME on my SC converted to a 3.6 had an intermittent short. The POS fuses had a wear spot from me spinning them due to salt corrosion by living at the beach.
I gave that panel the float test right after that discovery.
The relay really saves the electrical bits and pieces involved with the lighting circuits. Add up the costs...$50 for some relays is stupid cheap insurance.
Old 05-13-2021, 08:10 PM
... done no one else has said it: locate all the grounds on your car, undo the screw or nut and give them some TLC. Scotch Brite or fine sandpaper, clean with alcohol or DeOxit, assemble nice and snug. Just as critical to the free passage of happy electrons. Factory wiring diagrams do a fair job of showing where these grounds are located.
John
Old 05-14-2021, 05:19 AM
fred cook's Avatar
Pull the wires (one at a time!) at the fuse box and clean off any corrosion. A .22 rimfire wire cleaning brush is just the right size to use to clean the holes. Add a little smear of dielectric grease to help prevent future corrosion. Joe Bob is right, changing out the fuse panel for one that uses the ATO type fuses is the real fix. Not cheap, but effective.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 05-14-2021, 03:17 PM
Some wiring jobs I've seen on those ATO panels are pretty weird. Rather see a stock setup in good shape, that is wired normally, and can be diagnosed easily, but that's just me.
206 637 4071
Old 05-14-2021, 04:53 PM
John
yep, decided to check all the grounds, replaced all the fuses and cleaned all the connections. it all needed tlc.
thanks all!
Old 05-14-2021, 08:35 PM
