10mm Starter Barrell nut?
Can't find it in the catalog here, is it the same as the head stud barrells?
Pelican Parts - Product Information: 901-104-382-02-M260 Thanks for any help.
Gary R. |
The exhaust stud is 8mm.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Thanks, I know the exhaust stud isn't it, the link, photo, and question is referring to the head nut.
Gary R. |
I have a head stud nut and a starter nut in the garage I'll go photograph them for you. Sorry I about the above post I didn't look closely at the description.
ROW '78 911 Targa
You're good to go.
Page 150 of the '78-'83 catalog (pdf) says that it is the same part number. (item # 17, even described as cylinder head nut!)
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 03-18-2012 at 08:59 AM.. |
I don't have a starter nut. I have a head nut and threaded it to a case bolt as you can see. So I think it would work as a starter nut.
The starter cap nut has a narrower base. Simply take a head nut and grind the bottom to about 8mm and you have a factory piece.
The head nut willl work too with a good washer. Bruce |
I have been using the same head nuts for years. Never seen anything different used on the starter.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Finally got it off with some hammer/Kroil/Vice grip/swearing... thankfully I have a lift cause I would have gone nuts doing this on my back. The issue is simple, the stud is too long - even for the stock starter. The barrel nut keeps on going until you have only a few mm for the wrench to contact and it strips out leaving you with nothing to loosen it with. On the new high-torque the flange is even thinner so I used two 3/8" steel spacers (one on each bolt/stud) with washers and used a regular nut (easy to get at with the smaller hi-torq) on the upper stud. When I install the stock starter into my project I will use a spacer (size TBD) and a new barrell nut, making sure I have full depth for the allen wrench!
Thanks for the help, will order new a new nut..
Gary R. |
I've looked high and low for proper starter nuts and I'm unable to find them. Pelican Parts, our wonderful host recommended head nuts, 901 104 382 02 for my 1986 3.2 engine with a 915 gearbox.
The problem is that they (901 104 382 02 ) are a little short, about 1.2MM too short. The studs stick into the nuts too far and prevent proper tightening. The solution is a 1.9MM washer. Add in a wave washer to hold the nuts and it is perfect. Head nut 901 104 382 02 and the original side by side ![]() Head Nut ![]() Orginal ![]() Thick washer 1.2MM ![]() Head nut on washer = 18.6MM
The starter nut has a little different profile but a head nut should work fine.
here is the original starter nut which should be on there..it is 1,8cm long, the base is smaller only 1,6cm....it should only take regular flat washer and schnorr washer on top of it..then the nut....
that is correct way Ivan ![]()
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
100% agree.
Where did you get those proper nuts? Did you make your own? I need to buy a lathe. |
i have some just working on 911 for many years,people used them on the wrong places;-)
i`ll look how many i have... Ivan
The reason these are laying around is people use a head nut instead.
