Driver's License Owner
The Watson's Avatar
Monball / Koni Front install - Am I overthinking this?
My new Koni adjustable front shocks have this bumper and metal sleeve as part of the package.
The metal sleeve is longer than the rubber bumper and I believe the same diameter as the bottom of the Rennline monoball piece in the following pic.
Should the bumper and sleeve be omitted? Nothing about this in the Rennline directions. That would create metal to metal from the monoball to the dust cover. Is that the intent?
Am I missing something?????
Thanks -- Chuck
1977 911S Backdate Street/Track, 1970 911T, '70 Triumph GT6+ Vintage Racer Project, '60 MGA Restomod/tribute, Cayman R, 1967 Moto Guzzi V700
Old 05-18-2021, 12:52 PM
Yes, you're correct to omit. If you leave that rubber on there I would assume the shaft of the strut wouldn't make it above the top of the monoball to even thread on the nut. You'd have the same issue even with stock bushing up there instead of monoballs too. The dust shield will be sandwiched between the monoball and the larger diameter shaft under the dust shield.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 05-18-2021, 01:10 PM
The Watson's Avatar
Thanks Jacob!
Old 05-18-2021, 02:01 PM
