1989 930 3.2 engine run over after switch off
Recently the car develops the engine run over after switch off intermittently. Usually after after engine warm/a few miles drive. After searching the forum, I only found the thread with ignition delay relay on 930 Turbo which seems not related to my case.
It is the engine running roughly/jerky after the key switch off. Not the kind of delay to burn the fuel out as I search the forum. As I uploaded the clip;
https://youtu.be/RsurPz2YcVw
All the vacuum hoses checked with no leakage/breakage/lose.
A good known key switch was replaced but still run over intermittently.
Anywhere to start the diagnosis? Thank you.
Old 05-18-2021, 03:47 AM
flat6pilot's Avatar
That seems like it's dieseling. ?? Could it be a bad/dirty injector letting fuel by for a moment?
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 05-18-2021, 11:18 AM
I first thought that the leaky injectors were the cause. After took all injectors to check, they are all fine. No leak/drip.
Old 05-18-2021, 07:01 PM
proporsche's Avatar
what is your fuel mix set up C/O? with the oxy sensor disconnected and measuring in front of the catalyst?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 05-19-2021, 12:11 AM
Ivan
I do not have the CO meter so I never try adjusting the mixture at the air flow meter. The engine starts fine and drives normally. Only the dieseling intermittently (maybe 2-3 times out of 10 times).
Old 05-19-2021, 04:16 AM
Can you clarify as a 930 engine is a 3.3 did you put a 3.2 in it? 2 different fuel injection systems 1 cis the other efi
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-19-2021, 05:01 AM
Any chance you have a solid-state DME relay (assuming you have Motronic / 3.2)?
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 05-19-2021, 01:17 PM
Repaced the brand new DME relay yesterday but the problem persists.
Old 05-19-2021, 07:27 PM
Yes, the engine is 3.2 with motronic.
New plugs (factory spec).
All the vacuum hoses checked with no leaks.
Throttle valve, idle air control valve, and air flow meter cleaned.
Brand new DME relay underseat replaced.
Thank you.
Old 05-23-2021, 10:25 PM
Tags
930 3.2 , run over
