The Unsettler
Running Rough
Well got back to the car this weekend, adjusted the valves and now it runs real rough. Almost sounds like a miss but I don't think it is. Car runs and pulls strong, just sounds like a Harley and stumbles a bit at low revs.
Any ideas? Scott
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Senior Member
All else aside, I always tied a bad idle to tight valves in my multi-cylinder Japanese motorbikes. Is this possible?
John
'78 Targa in Minerva Blue |
The Unsettler
Hmmmm,
The idle is stable. It's running like a car that you start on a real cold winter morning, rough and you expect it to even out after a few seconds but it does not. Wonder if I did not get a plug wire on correctly somewhere. Scott
Senior Member
It's possible to push the Beru connectors down into the hole, and actually miss the plug terminal. You should feel each connector firmly grab the terminal fitting, or it may not be making contact.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
Beru connectors go Kaput also.. maybe measure the wire and connector if all else fails...........Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
