LinkBack | Thread Tools | Rate Thread |
Installing extra dashboard fog light switch for exhaust control valves
Hi all,
I'm planning the installation of my somewhat exotic exhaust setup on my 1987 Targa, and I want to sanity check my thinking. My exhaust setup is using a GT3 muffler with custom headers, that allow switching between primary and secondary. See details in Project: 997/991 GT3 exhaust on 911 3.2 ![]() To control the vacuum valves I'm planning on using an electronic switch from MaxSpeed that is controlled with a switch. ![]() Here I'm thinking to install an extra fog light switch in my dashboard, as my 87 Targa doesn't have the dedicated rear light switch, and got an empty spot. ![]() Parts needed for a new foglight switch: - Knob: 911-613-028-10 - Rosette: 911-613-213-03 - Switch: 911-613-147-00 - Cap: 911-613-234-02-01C Lastly, I'm thinking to have a custom button cap 3d printed, with an exhaust illustration on, to make it 👌 Does anyone have experience in installing another fog light switch? Was it straightforward? Thoughts? /k |
It’s very easy to install another switch
Pelican even has a tech article on installing a rear fog light that covers it . I just had a dash recovered and forget to tell them to give me another hole instead of the blank , so I bought a set of disposable scalpels off Amazon to do it myself . |
Full Send Society
Installing the switch into the dash is super easy, getting access to the rear of the dash requires the removal of all the blower stuff which is a real pain and the space is super confined. Not an insurmountable task but it took the better part of an afternoon for me to install a new fog light switch.
I would re omens lifting the front of the car as hunching over and trying to work in that space will be a less than pleasant experience. Also, packing blankets in the trunk to lean, lay on will be a lifesaver.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
if your car doesn't have a rear wiper or intensive washer option, you could also use either of these cavities in the instrument panel for the switch. I used the rear wiper one to install the switch for the manual override of my oil cooler fan & yes, I used a porsche rear wiper switch. Easy access.
Could you pull the head unit to gain access? I installed a rear fog switch in my 90 through that area after drilling a hole in the blank location.
Ralph W Instagram @ ralphwlll 1990 C2 Cab 2006 Nissan Frontier 1986 F250 |
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
