Happy New Year everyone !!! My new years eve was uneventful except for one stubborn CV bolt which yielded easily to a titanium drill bit.
I am just tidying up, I had a cam shaft o ring leak and discovered a broken nipple on the right tensioner so I am sending it out for replacement. ....thinking about different cams and P/C's. Anyone got any suggestions for Cams and P/Cs I already have the 46 PMOs and M&K 2/2 ? ![]() ![]() Aloha, Shane
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
Happy New Years Shane, I am in the proces of dropping my engine now also. Thanks for the motivation.
Royal Purple/Lilac, Signal Orange, Guards Red |
Congratulations! Right of passage... I'm partial to my WebCams... P/C very pricey if not required.
Chris 87 Carrera Coupe - Guards Red on black 00 Carrera Cab - White on Navy 05 Carrera S - Atlas Grey on gray 86 951 - India Red on black - Sold |
excellent.. welcome to teh club.
1982 Porsche 911SC Coupe - Factory Short Shift |7:31 R&P in AL case | Toyo RA1 Tires | Corbeau TRS seats | M&K 2 in 2 out muffler |
How long did it take to drop the engine? I need a tranny rebuild but am nervous about dropping it myself.
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Congrats Shane,
I was standing right where you are last week. At least you have a garage! You are ahead of me! Good luck with the repairs. Mack6820, if you are nervous about doing this for the first time (as I was) get a manual and read it, read it, read it, and then go at it. It is intimidating if you haven't done it before for sure. When you go to disconnect the accelerator pull rod there is a tiny little pin in the ball that you can barely see. Once I put my glasses on poof! there it was. Good luck.
"Charlie don't surf!" |
This engine has been out before someone had spliced a quick disconnect on to the reverse switch and the grounding cable looked pretty fresh, but there was a lot of grime and debris on top of the trans. I read through Wayne's 101 projects and used it as a reference.
Senior Member
Glad it went well... The first time I tried it... I actually dropped my engine about three feet. Crushed the tin and mangled the oil cooler. Sucked.
-- Chief Architect and Mastermind, SCWDP |
I hate freight charges
Nice work Shane!
I say 3.2 short stroke and a set of nasty cams ![]() I spent New Years Eve in Kailua watching some good friends get plastered and fall down! When I get ready to drop the engine from my Carrera don't be surprised if I give you a call. I actually went to the shop today and took most of my front suspension off to clean the inner fenders for paint. Found out I need both ball joints and outer tie rods.
Tom 78 911SC SC to 73RS imposter SCWDP crew #50 and 51 1969 Camaro "The new project"
I was just out in the garage trying to get the cam nuts off and I am pretty sure the left chain slipped a link.
![]() I only locked down one side and thought I had put the other tensioner in. Yep I am sure it slipped the engine only turned about 30 degrees after the slip, I haven't applied a lot of pressure. Can I just back of the valve adjustments and back that cam back up a link? Or should I just disconnect the chains? I want to take of the chain housings.
If you are taking the chain housings off, a retime will be needed. If you don't have Wayne's rebuild book you may want to pick it up. Just remember how everything comes apart so you can reinstall bushings etc as they were. Pictures are a huge asset.
Kevin '79 Coupe |
up-fixing der car(ma)
Lock the flywheel so you won't be turning the motor over while taking off the cam nuts.
Get Wayne's book, it is a great crash course/reference in 911 engines. Cheers,
Scott Kinder kindersport @ gmail.com |
Happiest when Tinkering
Great going Shane my first engine drop was over there in the islands, had to fix my tranny.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Great job and good way to spend New Year's...I've watched as my friend has dropped the engine in my car in a little over an hour (he has a lift and has obviously done this a number of times). Good to have friends that know what they're doing!
BTW, I like the Pelican sticker placement.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
Aloha Shane...I did the same thing 2 yrs ago on the same day!
Give me a holler if you need some tools or Wayne's book...I also have some notes from Jerry Woods and Bruce Anderson that may help. I can offer some assistance next week Sat. as I'm in the middle of doing my door frames now. I wish I knew the hex bolts were going to be a different size from what is in my car now...oh well live and learn. Let me know Bro!
Woody Slow n Fast 1984 Guards Red 911 Carrera |
Can I pressure wash the engine?
Before I get to carried away here, can anyone seee any issues with pressure washing a greasy engine?
I used something called purple power and a pressure washer on the transmission, it looks purty. ![]() Next up.... Mr. Leaky; ![]() I am not doing a tear-down , just replacing the cam shaft o rings and gaskets and re-timing the cams. To be continued.....
Damn! I gotta do that to my spare mag-cased trans
![]() Shane, I have one of the adapters for mounting your engine to a standard engine stand if you need it. Tom
Shane, Happy New Year!
Looks like you are having some fun in the sunny State of Hawaii. I am rebuilding a 1978 3.0L engine as well, so I will be interested in any thing you find here and how you solved it. Good luck with that. Are those SSIs (heat exchangers) I see peaking out the back of the engine? Cool.
Ed Paquette 1983 911SC 1987 944S 1987 944 Manual (Donated to the Nat. Kidney Foundation) 1987 944 Automatic (Recently sold to another Pelican) |
BTW...forgot to mention my suggestion:
964 profile/ground cams and late SC pistons and cylinders. Idea is from a friend up North of me whom suggested I do the same to mine.
Way to go Shane! I am in the middle of doing my first engine drop too. I am almost at the point of actually bracing the engine/trans on the jack and loosening the mounts. Scary!
Good luck with your tensioner fix, Michael
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 |
