privatepang's Avatar
Replacing alternator
Hi there,
trying to get to my alternator but I dont have that tool holding the fan in place so I can undo the bolt. Does anyone have any other ways of getting the fan off ?
Also what size is the bolt on the fan? I might as well get myself a decent breaker bar and socket for it.
1975 Aubergine 911S - Barney
"When that doesn't work, and it doesn't quite often, it's as though your face has been amputated." - Jeremy Clarkson
Old 08-26-2011, 10:25 AM
The fan nut is 22 mm unless there is a hex recess in the center then it is 24mm nut.
Bruce
Old 08-26-2011, 10:49 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pulley Wrench.
Check used parts, verify your model/year wrench
as there are different types/sizes pulley wrenches.
And, here's the easy way to hold the wrench in place while turning the nut.
DO NOT WEDGE ANYTHING IN THE FAN BLADES TO PREVENT THE ALTERATOR FROM SPINNING.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-26-2011, 11:02 AM
na2ub's Avatar
If there is a hex recess in the middle, you are all set, use that. If not, I have used a oil filter wrench before with limited success. There is no good way without the tool.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 08-26-2011, 11:51 AM
