Run for a short time and died
Hello
My 79 sc has been sitting in a garage for some time. Battery was dried out. I recharged the battery. Car started right up. After about 5 mins . Engine stopped. I turned the ignition switch, no power to the car. All electrical system shut down. Any idea ? Thank you
Old 06-05-2021, 05:39 PM
HarryD's Avatar
Is your battery flat again?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 06-06-2021, 12:41 PM
proporsche's Avatar
check your connection you just put on your battery..you could have bad ground or even those red wires on plus-side loose
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 06-06-2021, 01:55 PM
After a storage battery goes dry it most likely wont hold a charge.
Old 06-06-2021, 02:36 PM
Ivan
Found loose wires on plus side. Ordered a new 925 from Amazon. Still waiting on a terminal post. Thank you guys. Always helpful here !
Old 06-06-2021, 03:59 PM
proporsche's Avatar
u r welcome;-)
Ivan
Old 06-06-2021, 04:08 PM
Bill Douglas's Avatar
I don't think that green wire should be attached.
Unless someone used green because they didn't have another color. I'd still follow it and see where it goes.
Old 06-06-2021, 04:27 PM
You mean I should disconnect it ?
Old 06-07-2021, 04:34 AM
proporsche's Avatar
what he means is..the green wire is not an original part of the el.harness but in your case you should trace it what is it powering....most likely radio...? take picture where it leads and we will tell you ..
Ivan
Old 06-07-2021, 07:49 AM
Ivan
It goes back to the passenger side.
Old 06-09-2021, 05:39 AM
img]http://forums.pelicanparts.com/uploads26/11F6BC25_B0B2_4F3F_9CEF_93A8CC6763231623242685.jpg[/img]
Old 06-09-2021, 05:45 AM
proporsche's Avatar
to insert a picture go to the advance and there is a blue link to click on and insert pic
Ivan
Old 06-09-2021, 06:13 AM
HarryD's Avatar
Fixed, it was missing a bracket.
You need to see where it goes on the other side.
Harry
2020 MB E350 4Matic
Old 06-09-2021, 01:09 PM
proporsche's Avatar
good job Harry..still thinking it goes to the radio
Ivan
Old 06-09-2021, 01:39 PM
