Tachometer Disassembly Help
Watched some youtube DIYs ang got as far as prying the bezel off, unfastening 4 screws but the face still won't drop from the can/body. I think it's the bronze fastener at the bottom. Wanted to see if anyone has done this before and has some tips before I start monkeying around. Thanks in advance.
Old 06-27-2021, 04:56 PM
You need to remove the small black screw at the bottom of the face. Then the whole movement and face will come out.
Sent from my SM-G991U using Tapatalk
Old 06-27-2021, 05:15 PM
thank you i was thinking the same and started doing so but wanted to be sure...worried about scratching
Old 06-27-2021, 05:47 PM
Yeah be careful with the little screws because they're brass and easy to scratch.
Old 06-27-2021, 05:53 PM
Thank you for the help. Got it done and retrieved the little bulb rattling around in there.
Old 06-28-2021, 12:39 PM
