Hi all
I recently purchased a 911 3.2L Carrera Coupe The VIN number is as follows - WP0ZZZ91ZKS101328 The engine number is as follows - *64KO2662* How can I check if the engine in the car now (*64KO2662) is the one in the car when delivered Thanks in advance Pert Carrera 3.2L |
Are you in Australia or the US? In the US, the only way to tell for sure is to spend $500. See this recent thread: New Owner ? 1982 911SC Targa
But I don't think it is the original engine. According to the Red Book (referenced in the above thread), WPOZZZ91ZKS is for a 1988 non-US car, but engines that start 64Kxxxxx are US engines (type 930/25). Sometimes there are mistakes, so let's see if anyone else chimes in. Mark
1979 911SC Targa |
I think from the VIN it's an 89 model? The tenth digit is a K which indicates to me it is an 89 Carrera 3.2.
The 930/25 engines were fitted with catalytic converters for unleaded fuel so were used in the cars supplied to the USA, Canada, Japan, Australia, Switzerland etc. Again the K in the engine number indicates that this is an '89 version. I have an '87 Australian delivered car which is 64H and that is original. 88's had 64J (I was not used) and 89's had 64K engines. If this is an Aussie delivered 1989 Carrera 3.2 then it has an '89 engine in it which is more than likely original. Congrats! If you have the original service books it should have the engine number written in by hand in the first few pages. Otherwise you may be able to check with Porsche Cars Australia but not really sure. 911 CARRERA (S)(CH) 930.26 86 G 63G 10001>11000 6ZYL/3,2L/170 KW 911 TURBO 930.66 86 G 67G 00001>02000 6ZYL/3,3L/221 KW 911 TURBO (USA) 930.68 86 G 68G 00001>02000 6ZYL/3,3L/209 KW 911 CARRERA 930.20 87 H 63H 00001>10000 6ZYL/3,2L/170KW 911 CARRERA KATALYSATOR 930.25 87 H 64H 00001>10000 6ZYL/3,2L/160KW 911 CARRERA (S) 930.26 87 H 63H 10001>11000 6ZYL/3,2L/170KW 911 TURBO 930.66 87 H 67H 00001>05000 6ZYL/3,3L/221KW 911 TURBO (USA) 930.68 87 H 68H 00001>05000 6ZYL/3,3L/210KW 911 CARRERA 930.20 88 J 63J 00001>10000 6ZYL/3,2L/170KW 911 CARRERA KATALYSATOR 930.25 88 J 64J 00001>10000 6ZYL/3,2L/160KW 911 CARRERA (S) 930.26 88 J 63J 10001>11000 6ZYL/3,2L/170KW 911 TURBO 930.66 88 J 67J 00001>05000 6ZYL/3,3L/221KW 911 TURBO (USA) 930.68 88 J 68J 00001>05000 6ZYL/3,3L/210KW 911 CARRERA 930.20 89 K 63K 00001>10000 6ZYL/3,2L/170KW 911 CARRERA KATALYSATOR 930.25 89 K 64K 00001>10000 6ZYL/3,2L/160KW 911 TURBO 930.66 89 K 67K 00001>05000 6ZYL/3,3L/221KW 911 TURBO (USA)(CDN) 930.68 89 K 68K 00001>05000 6ZYL/3,3L/210
Davin '87 Carrera 3.2 '66 VW Camper '59 VW Beetle |
(man/dude)
A Porsche dealer can tell you (plus the transmission number), but it's at their discretion to do you the favor or not.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Or contact me, I can probably help.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
| Tags |
| australia , carrera 3.2 , g body |
