CJ CJ is offline
CJ's Avatar
Speedo Sensor Help
I just replaced the speedo sensor on my 87' and my speedo is reading roughly double actual speed. Any Ideas?
Chris Johnson
87' 3.4 Carrera
73' 911t restoration project
Old 05-07-2003, 10:26 AM
CJ CJ is offline
CJ's Avatar
Bump
Chris Johnson
87' 3.4 Carrera
Old 05-08-2003, 09:20 AM
addictionMS's Avatar
its not you, everyone else really going that fast...
sorry can't help really, but often an initial comment will get the others to spring into action
good luck
Jim
Jim Hamilton
If everything seems under control, your not going fast enough.
Old 05-08-2003, 10:56 AM
CJ CJ is offline
CJ's Avatar
Please, anybody?
Any theory appreciated.
Chris Johnson
87' 3.4 Carrera
Old 05-09-2003, 08:23 AM
Senior Member
ohecht's Avatar
It must be related to the frequency output of the new sensor.
Does anyone know what the spec of the sensors are, in terms of pulses/mile or some other frequency measurement?
Olivier
Olivier Hecht
1982 911SC
Old 06-29-2003, 06:05 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
One wheel rotation (both wheels) or two wheel rotations (one wheel while the other stands still due to the open differential) equals 6 pulses.
Are you sure you got the correct sending unit for your car?
ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 06-29-2003, 06:09 PM
Early_S_Man's Avatar
Porsche Crest
The sensor can be installed backwards in the transaxle housing ...
You might try flipping it over to see if that remedies the problem.
The sender is a simple magnetic reed switch ... some are defective out of the box ... perhaps quality control was lax and not all met spec as to magnetic field strength to operate the reed. It would seem to be a case of too weak tension on the reed if two closures [bouncing reed contact] is produced by each passing of the magnets on the ring gear carrier.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 07-01-2003, 11:25 AM
Senior Member
ohecht's Avatar
Has anyone heard the term "pole" used in this context, referring to the number of pulses per mile for the speed sensor output?
Olivier Hecht
1982 911SC
Old 07-01-2003, 12:16 PM
Porsche Crest
Olivier,
All of the references to number of pulses I have seen refer to pulses per revolution of the rear wheel & ring gear.
Warren Hall, Jr.
Old 07-01-2003, 12:34 PM
here is what a speddo ring looks like, Looks like 8 pulses to me....could there be more than one style, this is off a 915, ~1980s
Jim
Jim Hamilton
Old 07-01-2003, 01:50 PM
