Turn signal sign on rev counter
My turn signal indicator doesn't work properly, when you turn left it doesn't flash at all and when you turn right it the arrow on the counter flashes once and that's it, occasionally both arrows flash at the same time when you push to turn right, any ideas what might be causing this
Thanks Brian |
Most often it is because you have a light out, check your exterior turn signal lights, make sure they work, if not check to see that they are seated fully in the sockets.
Are any fuses blown? Also it could be your turn signal relay which is behind your left gauges, pull the left gauge to get access.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 07-25-2021 at 02:13 PM.. |
