Adding rear wiper?
What's involved in adding factory rear wiper to 3.2 Targa with factory Carrera tail? Any negatives to this? I've just always liked the way the Targa's looked with the rear wiper.
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 05-04-2021, 08:32 PM
toddadale's Avatar
I looked into; for my 1989 3.2 Targa. Not only the motor, arm - but a different real grill that has the hole for the motor to come though - Not to forget, the wiring! NOT WORTH IT!
If everything seems under control, you're just not going fast enough.
Mario Andretti
Old 05-04-2021, 09:04 PM
1988 Carrera
shadowjack1's Avatar
Not to hard. Most wiring is in place. First question is do you have A/C? If so you must replace the condenser in the engine lid.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 05-05-2021, 05:26 AM
My 930 has a rear wiper. Yes, I drive it in the rain. What’s interesting is that the rear glass never seems to get wet! I’ve never felt I needed it.
Old 05-05-2021, 06:35 AM
Porsche Addict
Gimmick.
Kinda like the headlight squirter/washer thingies.
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 05-05-2021, 02:45 PM
stevie 77 930's Avatar
It can be done but you'll need a host of parts...and its not as easy as some may indicate. I have done it. My car had non of the wiring in place, so i had to start from scratch
First you'll need the wiper arm , wiper motor, mount and correct wiper arm transmission (there are 2 different ones)
As mentioned a different rear A/C condenser is needed. The one with a rear wipe motor "cut out"
3 different wiring harnesses. The front harness from the switch to the the fuse panel The center harness from the switch to the engine compartment (front to rear of the car) The 3rd harness is the one in the engine compartment.
You'll need a wiper switch and the diode that goes to the switch
Ping Dennis "timmy2" for the center harness He made one for me. The front and rear harnesses are available from Porsche and not too expensive.
While adding the wiring in front and in the engine compartment isnt difficult, the center harness is a pain. I took the opportunity to do the center harness only after i dropped the motor to gain access to run the wire at or near the main harness in the center of the engine compartment.
The replacement A/C condenser is a whole project unto its own. Luckily for me, my system was already emptied of refrigerant. if not you 'll have to empty the system and ultimately get a recharge.
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 05-05-2021, 09:09 PM
autobonrun's Avatar
I have a 996 TT with the rear wiper and another Porsche without it. I’ve never used the rear wiper once. I couldn’t even tell you where the switch is located to operate it. There are threads out there where owners are trying to remove them.
Like you I like the look of the wiper, however I would not spend the money to add it. The downside of the wipers; a little more difficult to clean under it. Also there have been some that have reported damaging their paint when the wiper (when placed in the fully up position) suddenly slams down while cleaning the window. I never have this problem because I never lift the wiper fully when cleaning. I learn from others and just lift it slightly and wipe underneath.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 05-06-2021, 08:42 AM
So looking at the wiring connected to the on/off switch on the dash, it looks like the two red wires (one red/black, one red) connect to the two top spade connectors and the two brown (one solid brown, one brown/white) connect to the two connectors at the bottom of the switch? I just purchased a new switch and there are no numbers (e.g. 53, 53a, 31b, 31) stamped on the body of the switch to guide in the wiring connections at the switch.
Old 08-05-2021, 12:06 AM
Originally Posted by Larmo63 View Post
Gimmick.
Not if you actually drive your 911 in the rain, light mist on a highway with dirt roads leading to it. We drove through Northern Utah and the road had a layer of yellowish brown mud on it. I used about a gallon of wiper fluid on my windshield and headlights.
The heated outside rear view mirrors are likely the least used feature of the 3.2 Carrera models. In 26 year I have only turned on the mirror heaters twice.
I have never felt the need for a rear wiper on my 911.
Old 08-05-2021, 08:26 AM
Doesnt look like it would add any lightness to the car
Old 08-05-2021, 12:14 PM
