3.6 drivability problem
Hi everyone I have a 3.6 in an 82 after it runs a minute it won’t rev spits and sputters shut it off and restart driving down the road it fires and runs well for 20 seconds and starts sputtering again. I just cleaned the isv didn’t change any suggestions would be great. It’s a plastic manifold motor. Kevin
There has to be someone with an ideal
gduke2010
Engine wiring harness? Just an idea.
gduke2010
My symptoms weren’t the same as yours though.
I had a bad harness it didn’t start. It’s almost like after after starting it kick in to run mode then will barely rev.
Chain fence eating turbo
Which 3.6, the 964 or 993?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Worn tracks on the AFM can make them sputter and run really odd, but not sure about this..
Current: 1975 911S --Chocolate brown Past: 1967 911S --Bahama Yellow 1990 C2 Targa --Silver 1973 914 2.0 --Delphi Green |
Are you using the Silver Bosch Coils? If so its time to upgrade to the 993 Coil Pack
I think that maybe I'm dreaming.. |
Kevin,
I had a similar behavior on my 92 plastic-intake 964. It turned out to be one of the many vacuum ports on the intake manifold sprung a leak. I used cheap rubber grommet cups from your friendly FLAPS and they deteriorated over time. So check that you have no severe vacuum leaks on your intake. Two other issues that have gotten me are at various times and on both the Bosch Hammer was invaluable for tracking these down while driving. 1. The connector to the AFM is hitting the back firewall sound isolation. There is a Porsche TSB out to use a zip tie to force the wiring existing the plug to the AFM making a sharp bend to not hit the firewall when the engine moves under load in a stock 964. Depending on how low the engine sits in your car there could be interference. I then get the CEL and the engine idles and runs like @#@&* because the DME goes into limp mode. 2. At times my O2 sensor connector becomes wired to where the DME drives the mixture full-rich. And this causes severe bucking during cruise to where it feels like someone killed the engine. And then of course check all the basics starting with fuel pressure, caps, coils, make sure the belt in your distributor is still good, etc. Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Ok, the easiest test for checking if both ignition channels work is to unplug one ignitor while the engine is idling. Each time one of the two ignitors is unplugged the idle note changes slightly but the engine must not die.
Have you checked that you have sufficient fuel pressure and fuel delivery. I had a fuel pump going bad and this can cause what you see
