(man/dude)
MFI rocks, plain and simple. If it's at all an option, do it.
Been there, got the sticker! ![]() I've been farting around getting the 3.2SS on MFI working as well as possible and it can certainly be very, very good. It does take a bit of fiddling, but in 2021 the knowledge is out there, and the technology exists, with wideband O2 sensors, to color outside the CMA lines and tailor the system to just about any 911 motor. I'm not the first one to map out a space cam, but this is the "T" cam I am using to run the 3.2 in "Project Heavy Metal" which uses a custom machined big bore MFI induction system. ![]() (EDIT) - all that said, I've started purchasing components for an EFI/ITB system for my AutoX car. Everything has a place....
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Mark Jung Bend, OR MFI Werks.com |
(man/dude)
Thanks to You, and Jeff Higgins, and countless others here on the forum!!!
We have covered this ground oh so many times. Those with little or no first hand experience with a properly tuned MFI system will always say "modern EFI/ITB is better". And you know what? They are absolutely right. It is far, far better. More consistent fueling across the range of RPM, throttle position, and load. Better power across the range due to that. Better milage due to that. Cleaner running and less stinky due to that. Much, much better in every regard.
Except for "feel". A "feel" provided by that instantaneous throttle response. There is nothing else on the market that can match it. Modern EFI/ITB does come very, very close. But it is not there yet, and that difference can be felt. This difference is a lot of fun for some of us, some could not care less and won't want to put up with all of the downsides of MFI to get it. I understand that, especially considering just how close we can get these days, with none of the compromises. But, for some of us, those compromises are indeed worth it in the face of the "feel" MFI provides. You simply cannot get it with EFI/ITB setups, even as good as they are.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Eng-o-neer
This strikes me as a religious position from those with a vested interest in MFI being irreplaceable...
Racer
I have driven a well tuned 1973 911S and the throttle response was not any better than my race car's MoTec EFI setup with AT Power ITBs. I get that people want the MFI on cars that came with it or if they just want MFI on their 911 to be period correct or get that period feel from the best injection system available at that time. I would feel the same way if I had a 911 from the MFI period.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Mfi
I do think sentimentality plays a big part in our choosing MFI, but the fact is, it works wonderfully. 917 normal and turbo, 935, 936. I have a good friend who has raced for many years with both MFI and carbs. He presently campaigns very successfully a 3.0 RS with carbs and is after me to ditch the MFI, as he feels the PMOS/Webers are less maintenance. I have driven for years as a daily driver a 72 2.7 with MFI and the joy I receive from its performance and sound never fades. I track a 3.0 with MFI and I don't know what carbs could give me that the MFI doesn't but I think nothing, as the throttle response and pull with no flat spots is phenomenal. An image speaks to each of us differently, but if you had never seen one, this could cause one to pause. I prefer MFI for more reasons than performance.
![]() Quote:
![]() I've always wondered why so many guys who are ostensibly seeking some kind of a "vintage sports car experience" spend so much money, time, and effort to modernize them. Not just induction systems, but but modern brakes (Boxster caliper kits), modern suspension (coil overs, pick up point relocation, etc.), massive power increases (3.6's in early cars, etc.), modern A/C, and on and on. More power to 'em, just not for me. We all enjoy this hobby in our own way. That's what is important. Of course this "bench racing" is a large part of it as well. Fun stuff...
1979 911SC 3.2 SS Custom Backdate Hot Rod 1972 911T, 2.7RS Spec Beck 904 Carrera GTS /3.6 2023. Macan Previously owned several 911 models since 1975. |
Racer
Slides aren't even great for race cars. Butterfly setups, especially like the AT Power ITBs with shaftless butterflies, are better for street and race cars. The only advantage the slide has if ITB size is limited as it will flow more air wide open at any given diameter. The shaftless butterfly design At Power has pretty much eliminates that advantage. The barrel ITB is better than both but has issues of its own including cost and packaging.
https://www.highpowermedia.com/Archive/barrel-butterfly-or-slide
Interestingly, a walk through the paddock at the last Rennsport revealed a fair number of cars that should have had slide valves, that had them originally, that now had plain old butterfly throttle bodies. Not even high butterflies, which incidentally create their own problems as well. I've heard good things about Gamroth's new slide valves, like they don't stick and get gummed up like the old ones did. I have to believe, however, that they add more in "cool factor" than performance. And, yes, they are pretty darn cool...
slide valves
Racer
If you need slides for authenticity you probably wouldn’t be able to use “modern” slides anyway. I just don’t get the draw for slides on builds not constrained by authenticity rules. They cost more and don’t work as well as butterflies…
My 1970 911E had a 3.0 with Webers. It was 250HP and the car weighed 1900 lb. I've never driven MFI, but the throttle response with the Webers was pretty amazing. It occurs to me I'm referring to the car in the past tense. It still exists, I just sold it, is all. It's now somewhere in France.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
This thread makes me sad. Makes me miss my 69E, the only car I've ever regretted selling, the MFI being a big part of that and it looks like I'll never build a 4.0L MFI motor using one of the Catorce cases since no one seems to be getting a case.
Carry on.
Tru6 Restoration & Design |
MFI is a supercharger for fuel injection.
Chris 73 911 E |
T, E and S MFI engines are awesome but a 2.7 RS Spec MFI is a beast.
What causes the extra latency that makes the throttle response of an EFI/ITB engine to be worse than that of an MFI engine?
📸 https://www.instagram.com/porsche.tech 📸 |
