Ubi bene ibi patria
Hawkeye's-911T's Avatar
Beru Spark Plug Extensions
Hello to All
Could anyone please advise me of a part number &/or supplier for the threaded crimp-on spark plug lead for a Beru spark plug extension (from a 1970 2.2L engine) as per this photo:
I also need a replacement part number for the accompanying extension as per the photo below to suit the same threaded crimp-on plug wire end. The type offered by Pelican seem to be of the “wood screw” style of end fitting.
Any info or advice you can forward to me will be most appreciated & helpful - Thank you in advance.
Cheers
JB
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 08-30-2021, 03:07 PM
I would rather be driving
jpnovak's Avatar
The stock 70 Beru connectors do not have the crimp end. Unscrew the wire lead and you will find a "wood screw" terminator inside the connector. Just screw in new wires. Simple.
if your car has updated Beru connectors this is a Mercedes PN 0001591438 - BERU RHB003.
You will need a special crimper to do this properly. There is s lead crimp on the small shank and secondary crimp to secure the wire insulation in the outer collar.
Old 08-30-2021, 03:38 PM
Pelican lists them. Just ordered 100. I like to make my own wire sets.
206 637 4071
Old 08-31-2021, 07:03 AM
