Tips on testing the clock?
My clock doesn't work. I've busted out the multimeter and I have 10.5v coming from the harness. I'd like to test the clock on a battery. Any tips on how? I could grab any 12v battery, but I'm worried about overvolting if the clock is actually good.
When bench testing I use either an old PC power supply or my Milwaukee M12 batteries.
Hello - check out these past threads on clock repairs and also try the search feature - other members will also point you the relevant threads. Let us know if you have any other questions. Thanks.
Our sites tech article: https://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair2.htm http://forums.pelicanparts.com/porsche-911-technical-forum/874417-911sc-clock-repair-annotated-photos.html http://forums.pelicanparts.com/porsche-911-technical-forum/913721-vdo-clock-repair-incl-pictures.html http://forums.pelicanparts.com/porsche-911-technical-forum/145928-dash-clock-repair.html |
Thanks, Dmitry. I'd seen the "How-to" article, but it's frankly not very helpful. Lots of flowery language and discussion of buying his wife earrings (?) and maybe some waxing about his experience fixing a clock, but not testing the clock at all. If I'm not mistaken, it also is discussing a mechanical clock assembly, not the quartz "movements" in the later G-bodies. I should have been more specific in my post, admittedly.
I'll check out the other threads. Didn't see them when I searched. |
Checking you clock
On a 911 1970.
You can remove your clock Clock is made for 12v Earth body on - pole of the battery and set Plus pole to where your voltage cable should go. If you use a testprobe (or similar) as below, you can pulse 12v on the clock. http://forums.pelicanparts.com/uploa...1631877814.jpg |
just pull the 12v from car battery, its only going to draw the current it needs..
| All times are GMT -8. The time now is 12:57 AM. |
