Tips on testing the clock?
My clock doesn't work. I've busted out the multimeter and I have 10.5v coming from the harness. I'd like to test the clock on a battery. Any tips on how? I could grab any 12v battery, but I'm worried about overvolting if the clock is actually good.
Old 09-02-2021, 10:58 AM
Runnin on empty
acme911's Avatar
When bench testing I use either an old PC power supply or my Milwaukee M12 batteries.
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff.
https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html
Old 09-02-2021, 12:29 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - check out these past threads on clock repairs and also try the search feature - other members will also point you the relevant threads. Let us know if you have any other questions. Thanks.
Our sites tech article: https://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair2.htm
911SC Clock Repair with annotated photos
VDO Clock Repair (incl pictures)
Dash clock repair
Old 09-02-2021, 12:33 PM
Thanks, Dmitry. I'd seen the "How-to" article, but it's frankly not very helpful. Lots of flowery language and discussion of buying his wife earrings (?) and maybe some waxing about his experience fixing a clock, but not testing the clock at all. If I'm not mistaken, it also is discussing a mechanical clock assembly, not the quartz "movements" in the later G-bodies. I should have been more specific in my post, admittedly.
I'll check out the other threads. Didn't see them when I searched.
Old 09-02-2021, 12:43 PM
PC power supply; that's interesting. I might have a spare and if not its easy to get one. Do you just look for pins with appropriate voltage?
Old 09-02-2021, 12:45 PM
Runnin on empty
acme911's Avatar
Old 09-02-2021, 01:10 PM
Checking you clock
On a 911 1970.
You can remove your clock
Clock is made for 12v
Earth body on - pole of the battery and set Plus pole to where your voltage cable should go.
If you use a testprobe (or similar) as below, you can pulse 12v on the clock.
Old 09-17-2021, 04:26 AM
theiceman's Avatar
just pull the 12v from car battery, its only going to draw the current it needs..
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 09-17-2021, 08:11 AM
RDM RDM is offline
Coram Deo
RDM's Avatar
12 volts is 12 volts. As others have said, no worry about connecting the clock directly to the car battery or any other 12v DC source. Watch your polarity, though.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 09-18-2021, 12:31 AM
