One signal light flashing faster than the other
What causes that, I can't seem to find a fault other than too fast blinking?
change the light bulb on the fast light side...if not helping check the grounds
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
OK it must be the ground,
different bulbs on each side? the facct they are working but different rates leads me to that conclusion and you need to check all 4 corners while in there for absolute consistency of wattage
of course it never hurts to also clean all the grounds |
