headlight relay (again)
Hello all,
A while ago I purchase a blade conversion kit from fellow pelican Fred Cook. Getting ready to wire it, however I can't find the original wiring diagrams. I have searched here, but only to find relay wiring using 4 wire relays - mine are 5 wires.
I think I have figured it out looking a several threads - but then a problem comes up with the fifth wire - and two of the threads I looked have looked at, have conflicting info.
Bottom line - anyone have a copy of the instructions. Mush appreciated
Thanks,
Mark
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 09-11-2021, 11:50 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Relay.
Model/year of your car?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-11-2021, 12:18 PM
Old 09-11-2021, 01:30 PM
Eng-o-neer
Tremelune's Avatar
I don't have instructions, but the relays are standard Bosch automotive relays. They're all wired pretty much like this:
Old 09-11-2021, 02:07 PM
thanks, but I need one for a 5-wire relay. This diagram shows a 4-wire out.
The 5-wire relay has 2 - 87 terminals (not 87a and 87). I there is a yellow wire to one and a blue wire to the other. I am sure they go to the top of the fuse block, but in what configuration.
Thanks again for posting
Old 09-11-2021, 03:28 PM
on the relay is a diagram that shows when power is sent to 85/86 pair..... this engages the siwtch for a connection of #30 to both #87s.
Maybe I should switch these out for a 4-wire. But this is how the kit came to me. Not sure if Fred Cook is still a pelicanite. I have searched here for hours, and can not find any wiring diagrams specific to the relay set up in this kit
Old 09-11-2021, 03:39 PM
Synchro Joe's Avatar
Fred Cook is still on PP, you can do the 'go advanced' search for Fred and use the drop down link.
Timmy2 is also a great PP resource for all things 911 electrical.
Also see info here:
https://rennlist.com/forums/911-forum/840698-unsolicited-praise-fred-cook-s-replacement-fuse-panels.html
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 09-11-2021, 10:20 PM
ROW '78 911 Targa
timmy2's Avatar
Draw out the relay schematic.
You don’t need an 87a for headlight relays.
The double output on 87 (2 poles/contacts with the same normally open function) just means you run both to feed the top fuses for high or low beams. For low beams top of fuses 5&6
For high beams it is 7&8
Counting from the right side starting at the headlight.
Fred’s panels didn’t have internal jumpers, so dual output eliminates the need for jumpers.
Wire from 86 goes to the original top fuse wire for high or low beams (white or yellow)
Wire from 85 goes to a good ground.
Wire from 30 goes to a fused power input. (Battery or constant hot on fuse panel)
Repeat for second relay for high or low, depending on which you did first.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-11-2021, 11:50 PM
Thanks Timmy
Okay - I have been jacking with this for awhile and my mind is mush.
87 - running wires to top of fuses..... spliced with the one there or do these run thru the relay. Same on the bottom. Spliced or runs thru the relay?
Basically - the relay sets wiring sets between the top and bottom wires to the fuse. If so, then the original wiring run into the relay and the relay out goes to the fuses - replacing the original position of the factory wiring?
Old 09-12-2021, 07:45 AM
ROW '78 911 Targa
timmy2's Avatar
You don’t touch the original bottom wiring of fuses 5-8. Those go directly to the headlights.
For low beams select one relay.
You take the original top of the fuse yellow wire from 5 or 6 and splice it to the wire connected to 86.
You run 85 wire to ground.
You run 30 to fused power.
You run the 2 87 wires to the top of the fuses 5 and 6.
For high beams using the other relay.
Splice the original top of the fuse white wire to the wire going to 86.
Ground 85
Run fused power to 30
Run the 2 wires from 87 to the top of the fuses 7 and 8.
Dennis
Old 09-12-2021, 09:55 AM
thanks
appreciate it Mr Timmy
Old 09-12-2021, 02:08 PM
Lights.
Headlight relay wiring.
These pics will show you how to run your fog lights independent of your headlights.
Don't remember the headlight kit I used (a long time ago)...
These pics are for our M/Y 1986 Targa.
Good luck,
pm me as needed.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 09-12-2021, 03:29 PM
ROW '78 911 Targa
timmy2's Avatar
Originally Posted by mrm930 View Post
thanks
Post a photo or two of what you have done…
Dennis
Old 09-12-2021, 05:39 PM
