Tricky speedo problem
1987 3.2 Carrera Coupe. I asked PCA Technical and didn't get a response so I'm asking this community for help.
When my car is cold and I fire it up and drive speedo is spot on, I could drive 200 miles or more and speedo would be spot on BUT if I stop and trun the car off and then start driving again the speedo is dead, once the car cools down completely then scenario repeats. Otherwise the car runs flawlessly.
Old 09-21-2021, 11:51 AM
Call Palo Alto Speedo and ask. If this is common they will know what is going on. The capacitors may be going out inside the speedo. I just had mine in there for a bad plastic gear and they replaced the caps.
Sold: 1989 3.2 coupe, 112k miles
Old 09-21-2021, 12:00 PM
Send a message via AIM to fintstone
Could easily be the magnetic sensor or cable.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-21-2021, 11:06 PM
