1979 911sc key stuck in ignition please help
I’m looking fir some advice on removing the key out of my removed ignition.
I removed the ignition from my 1979 911sc and the key is stuck in the the tumbler. The key rotates through properly and the spring works at start accessories but fir the life of me I can’t get it out. Could it be that it requires power to remove? I’m trying to salvage this ignition to not be out $$$ Thanks for any help and guidance in advance. |
I occasionally have the same issue, although I haven't resorted to removing the ignition. Would like to know if there is a known solution.
Something that I found helpful was twisting the key slightly counter clockwise from the rest/off position before pulling. I am using a newer key that was cut from the key code, so it hasn't been worn down over time like the cylinder likely has.
'95 Coupe (2025-??) '86 Coupe (2021-2025) '82 Targa (2018-2022) |
ok,how did you remove the ignition switch with the key in it??You had to slide it out through little hole on dash..
Ivan
1985 911 with original 501 761 miles...807 506 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
I removed the 2 lock screws by drilling out then carefully played with the ignition until it popped out. Wasn’t as easy as if the key was removed… lol.
I’ve tried pretty much everything while it’s been clamped into my vice. I figured it would be easier to remove the key once it was out of the car with hopes to not brake the key off in the ignition. Perplexed |
cycling has-been
On my 77, it helped if I move the plastic part of the key up and down, left and right.
It has taken me the better part of 15 minutes to remove it on occasion. Don't force it. When you get it out, squirt a few drops of Kroil on the key and insert/remove a bunch of times. What happens is that the individual flags in the tumbler become gunked up, to the point where will not raise/release the metal part of the key on their own springs. If you have the tumbler out,keep dropping the Kroil down the key shaft - maybe every day until it comes free.
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 10-01-2021 at 01:04 PM.. |
Not a porsche ignition key. but I've had success with someone else going tap tap tap... With a small ball peen hammer or similar while I wiggle and pull on the key. You are trying to bounce the tumbler out while pulling it lightly.
it would nice if you can post picture of the ignition out and the position of your key in it..to post go to advance on bottom and there is a blue line to add pics
Ivan
I had that problem with a Fiat I had. I had to squirt some lube, or WD40, can't remember, and then it would slide out. Maybe you have some parts that are not moving as they should in there. Anyway, it's a quick easy thing to try.
JUAN '80SC Targa |
Thread Tools | |
Rate This Thread | |
