proporsche's Avatar
ok i know you have checked that......can you lift the rear of the car and try to spin the rear wheels?Of course it would be better on the ground but i do not know your set up.I would do it like this .I `d lift the left rear and start the car shift 1-2-3- with the right wheel on the ground...it will only spin the left-but only if you do NOT have limited slip differential!!
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-03-2021, 02:56 PM
Send a message via Skype™ to kyngfish
The fact that it seems to be rotational and increase when there’s braking - It sounds like some kind of movement when pressure is applied. I had a similar shake and clunk in my 124, it turned out to be that most of the bushings in the rear were shot and the rear was basically coming loose especially when braking.
It could be a CV, but I imagine if that was going then you would be hearing more of a click sound and it should be especially evident when turning.
Couple of other things to check. Check the sway bars, especially the rear, I had a clunk in the rear that ended up being a loose link, it sounded like that, but less rotational. Check the banana arm bushings, check torsion bar cover bolts, check and make sure the struts are torqued correctly.
When bearings go they are pretty damn loud, it should almost sound like a whoa whoa whoa whoa hum with maybe some screeching. Ask me how I know.
Only other thing I can think of is if the caliper itself has some kind of play in it and isn’t bolted down properly. And not for nothing but check and make sure the rear hub bolts are torqued properly.
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 10-03-2021, 06:06 PM
Wildman Emeritus
Thanks to all for advice. After running it with the rears wheels off the ground and still hearing it, I gave up and checked it into the hospital.
I found absolutely nothing loose. Anywhere. Pulled pads and rotated, shook rotors, spun and listened. Put it back together, ran as noted above and decided it is a DIY checkbook project.
Hopefully answer soon.
I strongly dislike giving up but also dislike spending $$ to fix what I think it is only to find it is something else.
Old 10-04-2021, 11:44 AM
Wildman Emeritus
Porsche hospital called. They claim to have isolated the noise to a rear rotor. Their suggestion was to replace my vented, cross drilled Zimmermans with stock rotors at all 4 corners. They strongly dislike crossdrilled rotors for some reason but I am not willing to replace 4 rotors when I can get by with 2.
So... I ordered a new pair of Zimmermans from our host and will replace just the rears when they arrive. Nice morning project.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-13-2021, 05:39 AM
tshebib's Avatar
It could be possible that the backing plate is bent slightly and rubbing on the rotor.
I had this happen to me when I replaced the rotors on my Toyota Tundra. When I pulled the old rotor off, the emergency brake shoes were catching on the drum part of the rotor and in turn pulled the backing plate slightly outward. I removed the new rotor, lightly tapped the backing plate back a little and bingo no more rubbing.
Old 10-13-2021, 06:43 AM
proporsche's Avatar
Mike never have i heard that the drill rotor will make a noise..i wonder who else is going to pitch in about it
Ivan
Old 10-13-2021, 07:04 AM
creaturecat's Avatar
if there is a point of contact - it should be reasonably obvious, no?
Old 10-13-2021, 07:46 AM
Wildman Emeritus
I believe there is a point of contact/ high spot on one rotor but it did not seem excessive. I will have a better look once things are apart and I can view both sides of the rotor and run a dial indicator over it on the bench.
I will get a look at the e brake assy and backing plate as well.
Old 10-13-2021, 10:37 AM
Same rattle
I have exactly the same rattle and have been throwing parts at it like crazy. It seems to be in passenger rear. Please, what did you find to be the source???
Old 09-24-2023, 08:28 AM
