Wildman Emeritus
Rotational Noise/Clunk
Spent the morning chasing a rotational noise that is more or less a low volume clunk. Now I need some suggestions as I could not sort it. Paying a pro is the last resort.
Symptom:
Rotational "clunk" that is audible but cannot be ascribed to a given wheel/corner
Braking enhances noise
Turning wheel to right enhances noise
Less noticeable in straight line or turning wheel left
Can't feel it in steering wheel or brake pedal
Do not think it's tires
Today's Efforts:
Raised car and checked wheel bearings wiggling and turning wheels
Fronts had more play than I like and snugged them a hair
Verified tightness of CV joints. Fine
Eyeballed front rotors and saw no evident high spots/shiny spots
Tomorrow's attack including any suggestions from you guys:
Raise azz end, jackstand. Run in 2nd gear and have wife hit brakes with clutch in. I listen.
Pull rear wheels, check caliper bolts and caliper holding screws
Put eyeball of death on calipers looking for high/shiny spots
So, please fire away with suggestions. As Ross Perot said, "I'm all ears".
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-02-2021, 10:33 AM
I can’t tell from your post, but is the noise coming from the front or rear?
Old 10-02-2021, 11:40 AM
proporsche's Avatar
can you tape the noise or video..it?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-02-2021, 11:56 AM
Wildman Emeritus
It seems to be coming from the rear. Not sure which side
Raining now but I will try to get a video/recording tomorrow when things are dry. I will get my wife in the car to help pinpoint the origin as her hearing has fewer rock concerts than mine.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-02-2021, 01:30 PM
proporsche's Avatar
dude ,you better not play while searching for the noise AC/DC.
Ivan
Old 10-02-2021, 01:32 PM
Wildman Emeritus
Noticed an error. Rotor holding screws. Should be tight as they were loc tited when emergency shoes were done 2 years ago.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-02-2021, 01:33 PM
Wildman Emeritus
Ivan
No AC/DC. More a Classic guy - Who, Cream, Tull, Doors.....
Old 10-02-2021, 02:50 PM
Wildman Emeritus
https://photos.app.goo.gl/D4NquVpu3KRZNynDA
Let's try this for sound.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-03-2021, 06:07 AM
Wildman Emeritus
Arreghhh. I will try to upload again.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-03-2021, 06:34 AM
Wildman Emeritus
I give up trying to drop a video, Been trying for 45 minutes and I am frustrated and done. Between google, android and Pixel phone it's a cluster. Thinking a trip for a new i phone.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-03-2021, 08:21 AM
Wildman Emeritus
https://youtu.be/s-McKxnJ6ys
Maybe......
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-03-2021, 08:39 AM
proporsche's Avatar
it does sound to me like a CV joint..not being loose but inside the cage...
Ivan
Old 10-03-2021, 08:46 AM
Wildman Emeritus
Ivan;
Thanks for the input. Is there a way to verify a CV issue before I drop a lot of $$ on a new pair of half shafts from our host?
Surprised as these were replaced about 20K miles ago with new Loebro half shafts and I lubed the **** out of them.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-03-2021, 10:51 AM
proporsche's Avatar
i would take them of the car and inspect.That means you have to slide the rubber boot off-to the center of the shaft(remove the small clamp-)If you have boot with a flange.
After mark the cv joint which way it came off.Remove the circlip on the end and take the cv joint apart.It is possible that the cage is broken.I do not think you have to buy the whole shaft just one cv joint if you find which is bad.Also was it even lubricated?
Ivan
Old 10-03-2021, 11:00 AM
Wildman Emeritus
Thanks. I will have a look tomorrow.
Yes, I lubed them when I installed them after trans rebuild. Liqui Moly LM47 and they were packed.
Other than lube issues, what causes failure? I sure don't beat on the drivetrain and the boots are intact.
Old 10-03-2021, 11:21 AM
If you suspect rear CV - perhaps check the mounting bolts are all tight...maybe they have loosened up a little since you swapped the shafts out previously?
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 10-03-2021, 11:27 AM
Wildman Emeritus
I looked at the paint marks on the CV and the bolts and still aligned. I will get the torque wrench on them to verify tightness before I go farther.
Old 10-03-2021, 11:41 AM
proporsche's Avatar
ok i listen again several times..you said you checked the rear wheel bearings.. if you turn right there is more noise....now come to think of it-and your axles are fairly new- possibly to focus on your rear left wheel bearing.....all tight,right
Ivan
the reason is ,if the cv joint would be really bad it would make more like scratchy noise not dung dung noise
Old 10-03-2021, 12:04 PM
proporsche's Avatar
don`t worry about the torque..they are tight enough;-)
Ivan
Old 10-03-2021, 12:05 PM
Wildman Emeritus
Suggestions for checking rear bearing. I lifted the car and pushed and pulled the wheel looking for play. It seems to have neither axial or radial play.
Old 10-03-2021, 02:45 PM
