headlight switch retaining nut
Hi, I'm after a new headlight switch retaining nut (the one requiring circlip pliers to remove). I have searched through the pelican parts catalogue but have been unable to locate it
. Would someone please be able to provide a part number or link if available.Thanks. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
You owe me a Crown Lager! Cheers, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thanks for the the parts diagram, I'll have the crown lager on your behalf
![]() Looks like pelican do not have these switch nuts, does anybody know of a source for new ones? Cheers |
If this is what you are looking for, I saved this one when I replaced the headlight switch in our '86. If not available from your local P-Dealer, pm me with your address, and you can have it. Now, about that Crown Lager................ Cheers, Gerry ![]() ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 01-16-2011 at 04:28 PM.. |
If it's the same one I'm thinking of I used the little knurled nut off of a presta vlave on my bicycle, the threads are identical. It is the little nut that holds the valve for your inner tube close against the rim, most people just toss 'em.
Kurt |
PM sent |
I had a split nut for the headlight switch. I purchased a version that was available and cut the nut to lenght and threaded the hole. The unthreaded blank hole was marginal almost marginal. It tap doesn’t give you 100% thread, but the stress isn’t that high.
