New Crankshaft Seal Leaks -Pulley End
My fresh 3.2 motor runs great!
But after the oil gets nice and warm I found a couple drips and it turns out it's from the crank pulley seal.
At first I thought it was the IMS cover plate but after removing the puley, I saw oil between the nose of the crankshaft and the inner lip of the seal.
The seal is an Elring seal. I've fitted heaps of these to new motors before so I don't know how I would have stuffed this up, but am hoping it was me.
I removed the seal, and to my eyes, it looks fine. I will order a replacement though.
I always install them with oil. If I managed to somehow damage it during installation, shouldn't I be able to see the damage on the seal lip?
I've had a good look at the crankshaft.. it is smooth, no burrs, no worn rings from old seals..
At this stage, I think my only course of action is to fit a new seal and cross my fingers...
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 10-03-2021, 11:04 PM
proporsche's Avatar
it is possible that the spring on the new seal is softer.What you do is take the spring off...untwist the connection ,each to opposite direction.Than cut the female side about 3mm and twist them both for a good fit .After put back on the seal.It makes it better grip and tension..
Just hope it is not your 8th bearing leaking.....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-04-2021, 12:01 AM
Ivan
Interesting.. never heard of that before.
Pretty certain it is not the bearing leaking. The seal removed nicely with one of those 2 legged seal pullers.. and it was dry all around. Also, the oil was easy to see pooling between lip of seal and crankshaft.. will take some pics tomorrow.
Always learning.
Old 10-04-2021, 03:51 AM
proporsche's Avatar
yup those are old tricks i have learned....do not put any oil on the outside surface of the seal if any use curil T or 576 Loctite orange....the seal once installed should be easy to remove.....just adjust the spring that should solve the problem should i show you how?
Ivan
Old 10-04-2021, 05:31 AM
Easily Confused
dtxscott's Avatar
Ivan
I'd like to see this.
Scott C.
'08 Cayenne GTS 6MT : '89 Targa GP White/Black - "Oliver's Car" : '11 Mitsu Evo X : '08 Lexus IS350 F-Sport : '01 Toyota Sequoia : 1998 Yamaha V-max : 1979 BMW R65
Old 10-04-2021, 06:44 AM
"Adjusting" the garter spring is a trick that's been used for decades. The only down side is that if you go too far, the sealing edge will wear a groove in the crank.
If you remove any garter spring, look carefully and you can see where the factory twisted one end into the other end.
Old 10-04-2021, 06:55 AM
proporsche's Avatar
working on it;-)..Now i know the correct name thanx dannobee..yup it is old trick which we used in Czechoslovakia where parts were hard come by..about 45 years ago;-)
ivan
Old 10-04-2021, 07:52 AM
proporsche's Avatar
ok here we have it .. 1st https://www.youtube.com/watch?v=OYxcT40i700
2nd
https://www.youtube.com/watch?v=Q83YRYcSpDE
just change the speed when watching..
Ivan
Old 10-04-2021, 08:06 AM
Easily Confused
dtxscott's Avatar
Ivan, thanks for making and posting the video. Very simple solution.
Scott C.
Old 10-04-2021, 08:24 AM
2nd
Ivan
nice!
is this something that can be done to the seal I removed? ie, can I reinstall a seal? or can it only be done to a new oil seal?
Always learning.
Old 10-04-2021, 11:49 AM
proporsche's Avatar
it could be done to a seal you removed..but my Q was how did you remove it without damaging it ? Those seals if they are in the 8th bearing are tight as tight i could be and you removed it with a pick? Can i see the pic and the seal you are trying to re-use?
Ivan
Old 10-04-2021, 12:23 PM
Might be your oil galley plug did you remove it or maybe machine shop
Have had this issue with a 930 a few shops replaced the seal but it still leaked
Old 10-04-2021, 04:28 PM
$20 seal. For god's sake, get a new one and cut the spring by 3mm.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-04-2021, 05:37 PM
Yea, it is just a few hours of work to get to the seal to replace it. I found that to be a real pain in the back.
Old 10-05-2021, 11:09 AM
proporsche's Avatar
i would like to know-still- how was it that the seal was easy removed and with tools??If any use ne seal and let`s see the old one ,the side of it...really they are very snug fit..
Ivan
Old 10-05-2021, 11:23 AM
Ivan
I am sure the sealing surface of the seal was destroyed in the process, even if it did not look it. Re-using it is a bad mistake.
Old 10-05-2021, 12:26 PM
proporsche's Avatar
exactly;-)i have never ever had luck removing it without making it kaput..not worth it...
it is strange to see tool being used to remove it..
Ivan
Old 10-05-2021, 12:33 PM
I wasn't planning to re-use the seal...
Even though it does look pretty good. Here are some pics of the seal.
I ended up installing another seal and so far, no more leaks. I've had a very good look at the Elring seal that I removed, and I cannot see any damage to the lip or cause for the leaking. The crankshaft is also in excellent condition with no grooves, or scores, etc...
Always learning.
Old 10-05-2021, 03:10 PM
The tool I used is similar to the one in this youtube video.... https://youtu.be/M_VQHvqXaYU
Always learning.
Old 10-05-2021, 03:11 PM
proporsche's Avatar
Mike, how about 1:05 on clock on the last picture of the seal???i see a difference..still..good you solved the oil leak;-)
on the video i do not believe that tool will not damage the seal......anyway problem solved...what is next?;-))))
Ivan
Old 10-05-2021, 03:41 PM
