Fuse for relay upgrade
Just did the headlight relay install. Went to the Battery + 12 for power. I'd like to put an in-line fuse on that wire. What amp. should I use ? Will a 25 glass amp fuse work ?
ALL of my electrics are rated for 30 amps so I put in a 20 amp fuse and that's just fine.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
a "rule of thumb" that I use is that the circut load should be 70% of the fuse................Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
that sounds about right as the lights use up to 16 amps tops. A little high but it's either that or upgrade to 40 amp electronics and I didn't see any of those at radio shack
Hey Tim.. I use the 75amp Bosch relay.. it has the screw attachments for the wires and nice big inner contacts.. Bosch # 0-332-002-150...................Ron
Thanks Ronin. I haven't done my high beams yet but I'll definitly have to use those. Where did you get them?
I'll look around for them. Are they DPST relays or SPST relays?
single pole.. I use 2 for the lights.. and I will be using one for that hot starter problem.. just to have it hooked up as a back up..beats crawling under the car, when I hit the desert, to screwdriver jump the starter sol.
oh yeah, they measure 1 3/4 X 1 1/2 X 1 1/4in.. I mount them for the lights foreward of the battery on the bulkhead.. just under the lip.. it's a clean install.............Ron
If you have relays in the circuit, then why do you need fuses?
Jerry M '78 SC |
Schleprock
I'd recommend a circuit breaker instead of a fuse.
When you blow a fuse, you need to replace it. When the circuit breaker pops, you reset it. I used manual reset 25A breakers for my 100W/90W install (12 ga. used for lights & grounds to handle increased load). Like these: http://order.waytekwire.com/IMAGES/catalog/215_56 And I also got some of the colored boots to protect the poles from accidental contact with something. Should I have used 30A breakers? 25A will just trip quicker in the event of a problem, no?
Kevin L '86 Carrera "Larry" Last edited by KTL; 05-16-2003 at 06:59 AM.. |
