3.2 Surging Idle
Hi,
Firstly, hello, I recently joined having bought an '88 G50 3.2 Sport this year.
After some advice on an issue that's driving me crazy.
  • Since I've had my car its had a jumpy idle when cold, in an effort to resolve I recently removed the ICV and cleaned, upon refitting the idle was much worse, surging between 1k and 2k RPM.
  • After doing various checks I decided that I would replace the ICV (it was an '82 part so likely not original). I ordered a new valve, excitedly fitted and for good measure replaced the jubilee clips as the others were a bit slack.
  • Now my car has a fast but steady idle at 1,2k RPM however as the car warms the RPM's gradually rise, when fully hot the idle surges between 1,2k and 1,7k. If i leave the car overnight its fast but steady when cold again.
  • When driving, if I close the throttle the car pulls gently and revs climb, the only way to slow the car is to ride the brakes or keep changing up
I have:
  • Checked voltage to ICV which is 12.6v (the valve also hums when powered on)
  • Checked the resistance on the idle microswitch in open and closed position and that it is clicking on and off as the throttle opens and closes
  • Overridden the ICV and attempted to set the idle but turning the screw seems to do nothing
My suspicion is that it is a mix problem, caused by a vacuum leak (I cant find anything obvious in the ICV area where I've been working) or potentially the car just needs the mix resetting but I am not sure. Speaking to a garage they are suggesting the AFM might be faulty or perhaps the ECU given its linked to temperature rises; the garage has a good rep but I am struggling to understand why replacing the ICV would now expose issues in those parts, a vacuum leak or setting the AFM up again feels more probable?
Any ideas on what to check and in what order? The garage can't fit me in until mid-Jan so its a long wait with a relatively new car
Thanks in advance.
Old 11-10-2021, 12:19 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Welcome to the forum and congrats to your 3.2.
As far as unstable idle do a search here and you will find lots of very informative threads dealing with this topic. In general you're correct that intake leaks affecting mixture at idle account for the vast majority of poor idle performance. Before you adjust anything it makes a lot of sense to track down any potential intake leaks. The main culprits are:
- deteriorating rubber hoses on the intake
- brake booster vacuum supply
- intake runner gaskets
Then it comes down to properly functioning sensors (CHT, IAT, AFM) that tell the DME how much fuel to inject and correct adjustment of idle mixture and throttle stop. Unfortunately, once someone messed with the adjustments to mask a problem you have to go back to the basics.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 11-10-2021, 02:30 PM
Try turning the idle speed down to 880 first.
206 637 4071
Old 11-10-2021, 04:24 PM
Sounds like my ‘87 3.2. Behind the throttle body is a real tight mess of vacuum lines including the large line that goes to the vac brake booster up front, the venturi assy, and about a dozen clamps.
Remove the air filter box, air blower and ducts, and look around at all the lines for cracks, loose clamps, etc.
Most importantly, check your rubber fuel lines.
Old 11-10-2021, 05:20 PM
Originally Posted by sidebp View Post
[*] Checked voltage to ICV which is 12.6v (he valve also hums when powered on)[*] Checked the resistance on the idle microswitch in open and closed position and that it is clicking on and off as the throttle opens and closes[*] Overridden the ICV and attempted to set the idle but turning the screw seems to do nothing[/LIST]
Check this link for evaluating the ICV;
Idle Valve Testing, post #20, Bench testing Carrera Idle Control Valve
Dave
Old 11-10-2021, 07:50 PM
I'll give it another go but when I did this before (inc overriding valve), turning the screw seem to have no effect.
Old 11-10-2021, 10:30 PM
Thanks, I actually followed this on the old valve, it was opening and closing with a 9v battery but when it was on the car there was no hum and resistance was not per Bentley manual so I decided to replace in the end. The new valve is humming and resistances per spec.
Old 11-10-2021, 10:31 PM
proporsche's Avatar
Did your garage checked the fuel mixture??
Ivan
1985 911 with original 501 761 miles...807 506 km
Old 11-10-2021, 11:26 PM
Can't get an appointment til mid Jan. Looking for another garage (this one has a good rep though hence the delay I guess)
Old 11-11-2021, 02:50 AM
Vacuum leaks!
Entire crankase venting system, intake needs to be checked. Oil cap to brake booster and cruise control . The little rubber tees behind the air cleaner that connect to nylon vacuum lines are cheap. Throttle body has a couple of vacuum lines so does fuel pressure regulator. There should be a diagram
Old 11-11-2021, 06:53 AM
That's because you didn't jumper the leads to take the ICV valve out of the mix.
Search how to adjust idle on the 3.2 on this forum. There should be a picture of the socket you need to jumper mounted on the left side of the engine compartment.
I'm in agreement with John Walker on this... adjust your idle first.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 11-11-2021, 08:56 AM
proporsche's Avatar
there is a relay for the plug and idle adjustment but wire will do
Ivan
Old 11-11-2021, 10:11 AM
Ivan
I did use wire to jumper the connections indicated. Perhaps it didn't have sufficient contact - will try again.
Old 11-11-2021, 11:38 AM
ischmitz's Avatar
It seems you're already far down the road of adjustments. However, contrary to some opinions here I'd always question why an adjustment is required in the first place. More often than not there is a primary problem that developed over time or suddenly (e.g. intake vacuum leak, fuel pressure or fuel delivery issues, condition of ignition components, worn AFM) resulting in poor running. Idle is particularly affected because intake leaks (un-metered air) have the biggest impact at idle.
Adjustments are then made in an attempt to compensate. However, if the underlying issue is not subtle the adjustment itself runs out of range or won't be effective. I would always go back and confirm basics check out before messing with idle adjustments:
- intake vacuum leaks
- fuel pressure and fuel delivery
- general upkeep (plugs, rotor, wires, valve adjustment, etc.)
- sensors (CHT, AFM, IAT)
Good luck and keep us posted on progress
Old 11-11-2021, 12:24 PM
proporsche's Avatar
here is a guide from Porsche 911 manual how to adjust fuel mix....
Old 11-11-2021, 12:33 PM
aus911's Avatar
Hi Ivan,
Do you have more info about this relay, My guess is the switch shorts jacks B and C together, but what do the green and red LEDs indicate? Did you make this?? Is this connector used for anything else?
Cheers
Ray
Ivan
Old 11-11-2021, 04:06 PM
You can pop the top off an old black relay and simply push the top contact down with your finger to do the same thing, if I remember right.
206 637 4071
Old 11-11-2021, 04:16 PM
You are aware that if the DME ECM ICV drivers are damaged, e.g. open/shorted, the jumper will have no effect, right?
Dave
Old 11-11-2021, 08:52 PM
Wasn't aware of this. Is it something I can test for?
Old 11-11-2021, 10:20 PM
proporsche's Avatar
that relay is a tool for 944 testing ..it is simple tool i got from the dealer back in the 1980`s...here
i liked the idea ..again wire does the same
Ivan
Old 11-11-2021, 10:54 PM
