Originally Posted by moush993 View Post
Thanks for the inputs. I ran the ohm test at the temp sensor plug at 70deg it read 2.5. I assume its ok.
If your ohmmeter indicated 2.5K (2500) ohms.
if car fails to start and I unplug sensor and jump the connectors will it at least start?
That only works when the engine is warm/hot. If the sensor is bad (open), the engine will always start when cold, but will make black smoke shortly after it starts.
If the sensor bad with very low resistance when cold, the engine will be difficult to start.
Dave
Old 12-01-2021, 05:38 PM
