berndtj's Avatar
Targa top not “flat”
Hi all,
My targa top’s center panel sits a little high. This causes it to catch the wind a bit more. I was wondering if there is any way to adjust this, or otherwise fix it.
Old 11-28-2021, 08:48 AM
Discseven's Avatar
Bern... remove the top and flip it over resting it on a flat surface. There are small hooks on the top that are designed to grip the cross members. Those hooks are adjustable. Once they get slightly loose, they can move out of optimal position and no longer grip the cross member... and the roof will look as yours does. The hook plates have screws in them and there's a backing plate behind the roof panel. Do not unscrew the hook plate screws too much or those backing plates will be very difficult to retreive and put back in position. Adjust the position of all the hooks and tighten their screws.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 11-28-2021, 09:16 AM
Discseven's Avatar
Here's a top rebuild. Backing plates are seen in post #87.
Targa Top Rebuild
Karl ~~~
Old 11-28-2021, 09:24 AM
berndtj's Avatar
Thank you! I’ll give that a shot. Much easier than I had assumed. I also need to replace the (sagging) headliner.
Old 11-28-2021, 12:46 PM
Discseven's Avatar
If the underside of your roof is in stock form, there's a coating of foam that if dried out... it's in crumbles. This can be a wonderful mess if not prepared for it. In other words, consider this when & where removing the headliner. BTW, the more you get into the roof, the more you may find to do---a black hole of sorts!
Karl ~~~
Old 11-28-2021, 01:35 PM
Discseven's Avatar
"Crumble."
Karl ~~~
Old 11-28-2021, 01:44 PM
berndtj's Avatar
LOL, it’s the winter in the PNW, so I’ve got some time for black holes . I really appreciate the responses.
Old 11-29-2021, 06:31 PM
I had the same problem with my 84......It looked just like yours..wind would lift it up more.
Bought 4 of these and it fixed the problem. The ones on the ends were doing the job.
https://www.pelicanparts.com/More_Info/96456526501.htm?pn=964-565-265-01-OEM&SVSVSI=911M&fs=0
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 11-30-2021, 05:27 AM
berndtj's Avatar
Well looks like my project is getting a bit more involved. Going to replace the vinyl as well.
Old 12-23-2021, 09:12 AM
sean m's Avatar
Did mine a few years ago. Really not hard, just need to take your time to get it right.
Sean M
'77 911S Targa Ice Green
Old 12-23-2021, 11:19 AM
Senior Member
Jdub's Avatar
With the weather we are having in the PNW I very much recommend you do this job in a nice warm area. Why? You want first off the best German grade top and second this piece nice and warm as you put the vinyl into place. Then, when you have stretched and assembled the top, the vinyl is as tight as it possibly can be. If you do this cold, the Summer will expose a flabby top. Trust me on this and good luck!
'78 Targa in Minerva Blue
Old 12-23-2021, 11:59 AM
HarryD's Avatar
I will add that if this is the first time the top is being redone, there is a high likelihood, the burlap is shot as well and the other lining materials. Unless you want to do the heroic repairs yourself, Dan Petchel does a most excellent job of renewing these things. Per Dan if rebuilding a 911 motor is a 10, top rebuilding is an 11.
Check out his site: https://www.carsincnj.com/targa-tops.html
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-23-2021, 12:56 PM
HarryD's Avatar
And this is a good DIY thread if you want to tackle it yourself: Targa Top Rebuild
Harry
2020 MB E350 4Matic
Old 12-23-2021, 12:58 PM
Seahawk's Avatar
I have PDF's of the Service School Manuals and the Service Training Center documents if you'd like. PM me.
I have had multiple Targa's and it does take time.
Best.
1996 FJ80.
Old 12-23-2021, 01:43 PM
redridge's Avatar
I remember this winter project... should be fun.
Targa Top Rebuild... a DIY
Old 12-23-2021, 02:04 PM
berndtj's Avatar
Wow, thanks for that link. I hadn’t seen that one before.
There really seem to be two camps regarding top recovering. Send it out vs DIY. My plan is to do this myself (in the winter) but I have a heat gun and a fireplace . If I fail, well I’ll be out a couple hundred, but what else am I going to do while is rains and snows.
I’m not going for concourse, just a hobby to learn on and drive.
Old 12-23-2021, 02:54 PM
berndtj's Avatar
Looks like webbing is intact, so that should keep things simpler. Though one of the posts (front) is stuck and I’m pretty sure if I force it I’ll have to replace the nut plate (which would require replacing the webbing, ugh). Current plan is to just not mess with it.
Now just waiting for vinyl and foam…
Old 12-23-2021, 03:41 PM
berndtj's Avatar
Also would love some glue recommendations!
Old 12-23-2021, 03:42 PM
Senior Member
Jdub's Avatar
[QUOTE=berndtj;11555419]Also would love some glue recommendations!
Fast Tack worked well for me.
Old 12-25-2021, 08:30 AM
Glue
I have used this product on my Targa top with excellent results.
When replacing a hood liner on a MB300 the parts manager said this is the product they use.
Get everything hospital room clean and work in a well ventilated area.
This product is available, the label has been changed.
Old 12-25-2021, 08:50 AM
