Epster77's Avatar
Window Motor Replacement Help Needed
My passenger side window is now rendered inoperative. It was working slowly last week and recently quit with a very hot motor. All the wires appear to be fine and all of the switches work. I am presuming that the motor is bad. What I would like to know, is this,,,,,Is replacement of the motor easy enough for a shadetree mechanic and if so, where can I find the procedure. The bad motor is on my 87 Cab and the window is in the up position. Any suggestions are appreciated.
Jimmy
87 911 Cab
www.pelicanparts.com/gallery/Epster
Old 05-15-2003, 06:24 AM
ruf-porsche's Avatar
If you can get a copy of Bentley manual for your car, they have a section on removing the window in the door.
Old 05-15-2003, 06:49 AM
JDaniel's Avatar
You don't need to remove the window to replace the motor. It's a bit of a wrist turner, but it can be done.
look here for some insight-
http://www.rpm.com.au/911/html/tech_w.html#winreg
at the bottom, in the window regulator how to.
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 05-15-2003, 07:03 AM
I used Wayne's 101 Projects to remove my regulator/motor. It wasn't very hard.
-Rob
1980SC
Old 05-15-2003, 09:37 AM
Epster77's Avatar
Thanks for the help guys.
JDANIEL>>Do you know if the removal can be done without the lowering of the window?? I cannot roll the window down,,,it is stuck in the up position.
Jimmy
87 911 Cab
Old 05-15-2003, 12:27 PM
Heck, I’m only 5 not 71!
targa80's Avatar
Your lucky, if the window was down you would probably not be able to get to the motor since the glass would be in the way.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 05-15-2003, 12:33 PM
JDaniel's Avatar
You should be able to answer that yourself after removing the door panel. Do not forget to tape the top of the window glass to the top of the door frame. You do not want it to come crashing down after you remove the bolts.
Dan Tolley
1987 911 Coupe
The Owner's Gallery
Old 05-15-2003, 05:23 PM
Epster77's Avatar
Thanks for the tips,,,I am picking up a new motor tomorrow and plan to attempt this repair on Sunday,,,I'll post about the progress. Hopefully all will go well.
Jimmy
87 911 Cab
Old 05-15-2003, 06:33 PM
Send a message via Skype™ to nr!que
tech_W
Hey there, first post here for me.
I saw this link but i cant get my window to move at all. I'm having trouble removing the motor. Help?
Old 12-27-2010, 01:44 PM
