Normal oil pressure for 75 911
What is the normal oil pressure for 75 911 and 3.0 engine.
Mine at 20 is that normal?
Old 12-13-2021, 09:54 AM
Functionista
manbridge 74's Avatar
From the manual.....
Should not be below 50.7 psi at 2500 rpm. Should read 65 psi at 5500. Normal to drop below 14.5 psi at idle, but above mentioned values must be there. All values at oil temp 176F.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 12-13-2021, 11:47 AM
Flat Six
Flat Six's Avatar
About 1 bar per 1000 rpm when warm
Old 12-13-2021, 12:12 PM
Does the 75 still have the 10 bar gauge?
Old 12-13-2021, 01:03 PM
Walt Fricke's Avatar
Icepick may think he was specific, but he wasn't. A '75 2.7? A '75 upgraded with a 3.0?
The 2.7s had the 10 bar pressure sensor and gauge. The 78 on SCs had 5 bar for each. If you want to fool yourself, put a 5 bar sensor with a 10 bar gauge!
Old 12-13-2021, 01:53 PM
i guess ill just change the sensor to 10 bar and see.
Old 12-14-2021, 01:40 AM
Video attached
https://youtube.com/shorts/j1v8RStcgZY?feature=share
Old 12-14-2021, 03:39 AM
