Fuse for relay upgrade
Just did the headlight relay install. Went to the Battery + 12 for power. I'd like to put an in-line fuse on that wire. What amp. should I use ? Will a 25 glass amp fuse work ?
Old 05-13-2003, 01:27 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
ALL of my electrics are rated for 30 amps so I put in a 20 amp fuse and that's just fine.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 05-13-2003, 01:29 PM
Cool
a "rule of thumb" that I use is that the circut load should be 70% of the fuse................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2003, 06:04 PM
Tim Walsh's Avatar
that sounds about right as the lights use up to 16 amps tops. A little high but it's either that or upgrade to 40 amp electronics and I didn't see any of those at radio shack
Tim
1973 911T
2005 VW GTI
Old 05-13-2003, 06:17 PM
Cool
Hey Tim.. I use the 75amp Bosch relay.. it has the screw attachments for the wires and nice big inner contacts.. Bosch # 0-332-002-150...................Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2003, 06:57 PM
Tim Walsh's Avatar
Thanks Ronin. I haven't done my high beams yet but I'll definitly have to use those. Where did you get them?
Tim
1973 911T
2005 VW GTI
Old 05-13-2003, 06:58 PM
Cool
Originally posted by l33t9eek
[BRonin.
Where did you get them? [/B]
Tim... I'm not the greatest financial manager.. so I see them in an FD/PD supply catalog.. Galls Inc., 1-800-477-7766, item# SE057.. they cost me $19.99 each.. somebody who knows what they're doing should be able to get them much cheaper.. it's like a real weather proof relay for under hood FD/PD christmass lights, etc.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2003, 07:06 PM
Tim Walsh's Avatar
I'll look around for them. Are they DPST relays or SPST relays?
Tim
1973 911T
2005 VW GTI
Old 05-13-2003, 07:11 PM
Cool
single pole.. I use 2 for the lights.. and I will be using one for that hot starter problem.. just to have it hooked up as a back up..beats crawling under the car, when I hit the desert, to screwdriver jump the starter sol.
oh yeah, they measure 1 3/4 X 1 1/2 X 1 1/4in.. I mount them for the lights foreward of the battery on the bulkhead.. just under the lip.. it's a clean install.............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-13-2003, 07:33 PM
Randy Webb's Avatar
If you have relays in the circuit, then why do you need fuses?
Old 05-15-2003, 04:28 PM
Battery to fuse to relay to lights = 1 circut
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 05-15-2003, 04:59 PM
Because relays do not provide overload protection, they're essentially a switch.
Jerry M
'78 SC
Old 05-15-2003, 05:12 PM
KTL KTL is offline
Schleprock
KTL's Avatar
I'd recommend a circuit breaker instead of a fuse.
When you blow a fuse, you need to replace it. When the circuit breaker pops, you reset it.
I used manual reset 25A breakers for my 100W/90W install (12 ga. used for lights & grounds to handle increased load). Like these:
http://order.waytekwire.com/IMAGES/catalog/215_56
And I also got some of the colored boots to protect the poles from accidental contact with something.
Should I have used 30A breakers? 25A will just trip quicker in the event of a problem, no?
Kevin L
'86 Carrera "Larry"
Old 05-16-2003, 06:45 AM
