ornas's Avatar
Location: Vilnius Lithuania (it's in Europe and it's not Russia)
Please help modify 930 odometer from mph to kmh
Recently my odometer stoped working, so I decided to modify my speedometer from mph to kmh. I have sourced km/h gauge bazzel localy, but do not know what to do with gears. Could someone tell me what gear should be changed to make odometer turn in km?
Old 06-10-2015, 09:07 AM
aircooled addict
jimbeaux911's Avatar
no need to change any gears. Km/h is proportional to mph. the new faceplate is the only thing that needs to change.
many dials have both, with only one set of gears.
Old 06-10-2015, 10:15 AM
ornas's Avatar
Changing face plate is an easy part, but I want to make odometer turn in km, not in miles.
Old 06-11-2015, 12:00 AM
universeman's Avatar
Contact North Hollywood Speedo.
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 06-11-2015, 01:15 AM
E900's Avatar
He's saying the layout of the mph faceplate is the same relative to the speed as the kph one is. So if the needle is at 62 mph, and you would drive the same speed the kph faceplate would say 100 kph.
Old 06-11-2015, 01:51 AM
Almost Banned Once
sc_rufctr's Avatar
You have to change a gear in the mechanism...
Start here. http://www.odometergears.com/documentation/Porsche_911_20_x___Odometer_Gear_Replacement.pdf
But you have to know how many teeth you need for kms. Sorry can't help on that.
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI
- Peter
Old 06-11-2015, 01:56 AM
porschetub's Avatar
Been thru this myself,correct on what you say,miles read @ a differant geared rate to kilometers,our crazy government made you put a sticker over the speedo in your european car years ago because they deemed the public too dumb to work it out for themselves that they couldn't work metric to imperial conversion .
I get tired with replies like send it to NHS when it isn't an option due to cost/exchange rate or location,in my case I have been talking with Howard Instruments in Australia they have a full service for Porsche VDO.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 06-11-2015, 03:07 AM
ornas's Avatar
On rennbay they say
"1974 - 1989 Km/h Gages - Most use the 20x21 tooth gear but some still used the 20x30 tooth gear. You must count the teeth on your old gear to be sure. It will be one of these two gears. "
This makes me a bit confused, couse i thought that secondary must rotate 1,6 times faster, but 20x21 gear would require larger secondary gear that would couse even slower odometer rotation
I have asked nhs if they could sell me a mph/kmh conversion kit, but they did not respond.
Old 06-11-2015, 08:02 AM
Dial 911
A horse with no name's Avatar
Recently my odometer stoped working, so I decided to modify my speedometer from mph to kmh. I have sourced km/h gauge bezel localy, but do not know what to do with gears. Could someone tell me what gear should be changed to make odometer turn in km?
Hi, our host sells them:
911 Euro-KM and Asian (Base, Carrera, SC, Turbo) 1975-1989 *20x22 or 20x32 ODO-POR-20-22 or ODO-POR-20-32 n/a n/a *Must be confirmed prior to ordering.
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 06-11-2015, 12:11 PM
ornas's Avatar
Any ideas where I can source the secondary gear?
Old 06-11-2015, 10:42 PM
Dial 911
[QUOTE=ornas;8663916]Any ideas where I can source the secondary gear?[/QUOTE
I believe that our host does. Use their ' contact' form and ask them
Cheers!
Leonardo Da Vinci
Old 06-12-2015, 01:45 AM
ornas's Avatar
[QUOTE=A horse with no name;8663980]
Pelican has only primary gear
Old 06-12-2015, 05:42 AM
Dial 911
Try North Hollywood Speedometer and Clock- They have been in business since 1955 . If anybody has or knows where to source one I would they would.
Here's there link.
info@nhspeedometer.com
Cheers!
Leonardo Da Vinci
Old 06-12-2015, 10:35 AM
ornas's Avatar
Found out that difference is in electronics, gonna try to make an adapter
Old 06-15-2015, 07:55 AM
Old thread I know, but did you ever get a solution to this?
Cheers,
Frank
76 911S
Land Rover 110 Defender
Old 12-30-2021, 04:42 PM
7783911's Avatar
contact JBELL on this forum...does geat work
Old 12-31-2021, 05:33 AM
Another shout out to Jbell. Great communication, quick turnover and very reasonably priced
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 12-31-2021, 02:06 PM
Cheers,
Frank
The board is the same for both but all 3 gears need to be changed and it will need to be recalibrated. The earlier ones have a potentiometer on the board to allow for calibration, but the later ones do not. On the later ones you need to replace one of the resistors with a potentiometer to do this conversion.
I haven't bought the conversion gears in a while but there was a place in Germany that was selling them. That was the only place I could find them at the time.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 12-31-2021, 09:32 PM
Daugaard's Avatar
This:
https://www.ebay.de/itm/392162988622?fits=Make%3APorsche&hash=item5b4ebc524e:g:nLoAAOSwvOdhzG57
From miles to km/h
Daugaard
Old 01-01-2022, 08:19 AM
Originally Posted by Daugaard View Post
Yep... Those are the correct gears
Old 01-01-2022, 08:58 AM
