-   -   Not another battery tray thread (http://forums.pelicanparts.com/porsche-911-technical-forum/1109834-not-another-battery-tray-thread.html)
911finally 01-01-2022 07:49 PM
yes it is! After reading many I still have questions about what I should do.
Had this CTRL+X
http://forums.pelicanparts.com/uploa...1641094668.jpg
and then CTRL+V with new sections from Resto Design
http://forums.pelicanparts.com/uploa...1641094811.jpg
Little exposed area in tray which I scraped all the way back to edges at front and along tank
http://forums.pelicanparts.com/uploa...1641094863.jpg
http://forums.pelicanparts.com/uploa...1641094994.jpg
Questions
1- what should I use to clean off remaining residue? (I plan to use the POR15 clean, prep, coat kit to treat the whole area once cleaned up)
2- I can't get under tank (don't want to remove) and don't want to strip past the edge of the battery tray - do I just do the POR treatment to the edges, then overspray the whole area and into existing coated sections with a rubberized coating like Transstar?
Appreciate any recommendations on steps.
ian c2 01-01-2022 08:31 PM
Have a look here at rust remover and pressure/capillary action to cover bare metal .
http://forums.pelicanparts.com/porsche-964-993-technical-forum/1018128-finally-got-my-car-back-2.html
Not sure where your pics are located , but it]f it’s a vertical section you can either get creative to make a “bath” and use the liquid rust treatment , or buy the gel version ,
