Not another battery tray thread
yes it is! After reading many I still have questions about what I should do.
Had this CTRL+X ![]() and then CTRL+V with new sections from Resto Design ![]() Little exposed area in tray which I scraped all the way back to edges at front and along tank ![]() ![]() Questions 1- what should I use to clean off remaining residue? (I plan to use the POR15 clean, prep, coat kit to treat the whole area once cleaned up) 2- I can't get under tank (don't want to remove) and don't want to strip past the edge of the battery tray - do I just do the POR treatment to the edges, then overspray the whole area and into existing coated sections with a rubberized coating like Transstar? Appreciate any recommendations on steps.
_______________________ '85 Black ROW Coupe (trying to put back together) '88 Blue 951 (sold) '84 Blue couple (sold) |
Have a look here at rust remover and pressure/capillary action to cover bare metal .
Finally got my car back !!! Not sure where your pics are located , but it]f it’s a vertical section you can either get creative to make a “bath” and use the liquid rust treatment , or buy the gel version , |
