Help identifying cylinders
Hi. I’ve managed to buy a set of Mahle cylinders for a rebuild that I’m doing. These were sold as 95mm but they measure 98mm. They don’t look like they have been previously bored out and they don’t show any skirt markings. I can’t see them mentioned on here as anything other than 95mm. I was wondering if they were aftermarket big bore???? The markings stamped are 95ZN1 W16 wth A8 below.
Old 01-26-2022, 01:27 AM
pics would be a big help
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 01-26-2022, 05:54 AM
I tried to upload some pics but couldn’t. I’ll try when I get home from work.
Old 01-26-2022, 07:15 AM
Here you go. They measure 98mm diameter, no other markings that I can see.
Old 01-26-2022, 07:16 AM
Complete cylinder pic from the top would tell us more. hopefully bored 3.2 carreras without the sealing ring groove.
206 637 4071
Old 01-26-2022, 01:17 PM
Old 01-26-2022, 02:02 PM
They don’t look like they have been bored out, too thick still
Old 01-26-2022, 02:03 PM
98mm 3.2 Nikasil cylinder 1974-1979/80. Mahle documentstion was poor in this period. I believe some 95 designated cylinders were actually made 98mm for the 3.2 engine.
It may be the ++ is the key part of the designation indicating they're 98mm / 3.2 cylinders.
If your German is ok there is a little more info here. http://elferszene.de/showthread.php?t=23781
Sent from my SM-G988B using Tapatalk
Old 01-26-2022, 10:18 PM
If your German is ok there is a little more info here. Bezeichnung an den Mahle Zylindern beim 3,0 SC - Elfertreff - Das 911 & Porsche Forum
Thanks for the link, it’s an interesting read and gives me an indication of what I have. I love the idea that the factory built engines based on random shelf picking of core components.
Old 01-26-2022, 11:08 PM
Schulisco's Avatar
Translation with Google Translator:
https://elferszene-de.translate.goog/showthread.php?t=23781&_x_tr_sch=http&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 01-27-2022, 04:58 AM
Turbo, 97mm, are based on the 95N1, etc
98 mm are opened for 3.4.
Bruce
Old 01-27-2022, 01:55 PM
