Dumb questions about my 79' SC - CIS
A couple questions,
1. Is the CIS a stand alone system? 2. Is the ignition system a stand alone system? The main thing is, is there a main DME that if I were to change the fuel injection and/or ignition system, would that effect any other body functions? I did a search and cannot seem to make the determination that the 79' SC even has a DME. For example, if I did a PMO carb conversion, would I have to reprogram a control unit to not look for the CIS? or would it be as simple (right?) as removing the CIS system/wiring/control unit and then installing the carbs and of course correct fuel components. Thanks,
1979 911 SC Gran Prix White. Gone but not forgotten. 2016 GT4, current steed. IG @hulley31 |
A simple swap, Why would you want to change?
Power? CIS not working? feel like spending money? Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
So basically, feel like spending a little money. ![]() When you say "a simple swap" does that mean that the CIS is a stand alone system? No DME?
Hulley, Your 1979 SC does not have an ECU nor DME. If you have a desire to make your CIS motor to run faster and quicker, contact Ian Carpenter (ICarp). I had been on Kermit and could not believe how well this car with CIS performs on the road. I though it had carbs in it. Tony |
Coram Deo
The first step in cleaning up your engine bay is a heater backdate. This is aided by installation of SSIs, which will get you a bit more responsiveness and performance. Many threads on that topic.
A CDI+ box will give you programmable spark advance, which again gives you a bit more responsiveness and performance. And no- no DME. No interface between intake and ignition systems.
Dru 1980 911SC Targa Petrol Blue Metallic Cork special leather Sport Seats Limited Slip 964 Cams SSIs Rennshifter 1990 250D Opawagen 1995 E220T Sportline Familienwagen 1971 280SE Beverly... hills that is 1971 Berlina 1750 Faggio Last edited by RDM; 02-05-2022 at 08:38 AM.. |
As stated earlier, no DME/ECU on a '79 CIS. My CIS never gave me any problems.
I'd also agree the fugly-est thing in the engine bay is that heater fan and the plastic and paper hoses running all over. But heat might be a requirement? (It is up here in PNW.) Later models hid two fans up front. If you have a sunroof, cracking it open about an inch creates a vacuum that pulls more heat than the heater fan ever does. CIS has a large air-flow meter plate that is sensitive to blow-back that might be caused by intake valves opening too early. Therefore, you'll read about CIS owners trying to find the best cams that don't step over this line. Or they replace the CIS. Maybe your driving goals won't require you take that step? It's already a Porsche and has wonderful performance. If you start down the slippery slope, it's a good idea to know where you are going to get off. Michael J. '78 SC (CIS replaced by BITZ EFI) |
Based on your questions about CIS, ignition and DME you need a better understanding of the CIS system before making changes. May I suggest you review the CIS Primer for the 911.
Thank you all for the input, Pelican really is a great place to be!
