Incorrect instructions with new voltage regulator?
The instructions that came with a new Porsche voltage regulator that I bought from Pelican seem to be incorrect.
Here are the connectors on my alternator after removing the voltage regulator. The B+ connector on the right is a little burnt. The connector on the left is D-.
Here is the regulator I removed next to the one that came from Porsche. The one I removed has a single wire to the B+ terminal, the new one has two wires.
Here's the instructions that came with the new regulator.
I found this service bulletin, which says to connect the blue wire to D-, the yellow wire to B+.
Which is correct?
Old 02-12-2022, 01:12 PM
Bump in hope of finding the answer
Old 02-21-2022, 06:26 AM
