Incorrect instructions with new voltage regulator?
The instructions that came with a new Porsche voltage regulator that I bought from Pelican seem to be incorrect.
Here are the connectors on my alternator after removing the voltage regulator. The B+ connector on the right is a little burnt. The connector on the left is D-. ![]() Here is the regulator I removed next to the one that came from Porsche. The one I removed has a single wire to the B+ terminal, the new one has two wires. ![]() Here's the instructions that came with the new regulator. ![]() I found this service bulletin, which says to connect the blue wire to D-, the yellow wire to B+. ![]() Which is correct? Last edited by Tom F2; 02-21-2022 at 07:28 AM.. Reason: Shorten and simplify |
Bump in hope of finding the answer
