Kind of Blue
MrBonus's Avatar
Fan Strap Removal - Passing Strap Under Fan
So I managed to wiggle the original strap (77 motor) past the distributor but it seems to be hanging up under the fan. Is there a trick here or have I created a mess for myself?
I’ve tried using a flathead to pass it underneath but I swear the the strap won’t fit under the housing.
Any tips or tricks? I’d really like to knock this out easily.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 02-26-2022, 03:08 PM
Walt Fricke's Avatar
How about lifting/tilting up the fan housing after removing the fan belt? You may have to loosen some of the shroud, as if replacing the alternator or the like. Not sure I have had to do this, but no special trick.
Old 02-26-2022, 03:17 PM
Senior Member
Superman's Avatar
With the housing removed, the strap needs to be tweaked in order to come out of the brackets molded into the case. At the bottom, the strap goes through some passages in the engine case. The strap needs to be bent a little in order to get out of those passages.
Mocha 1978 911SC. "Coco"
Old 02-26-2022, 03:21 PM
Kind of Blue
MrBonus's Avatar
Needlenose locking plyers don’t fail me now.
Old 02-26-2022, 03:28 PM
Full Send Society
If I recall correctly the shroud and fan housing need to be removed as the strap is threaded through some tight spots and needs to change angles a few times to be unthreaded.
I ended up cutting mine off as it was rusty and replacing it with a rennline strap.
If you zoom in at the bottom of the pic to the right of where the coil is resting you can see the passage way. Very tight.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 02-26-2022, 03:57 PM
The oil pressure switch is in the way also. Loosen the fittings and lay it flat.
The strap is installed before the fan housing.
206 637 4071
Old 02-26-2022, 04:02 PM
Grappler
Rodsrsr's Avatar
It can be done without removing anything. I ran into this same issue with my 3.2. Installed the fan, shroud and than the strap. It was difficult but I think I used a long screwdriver and tapped it in on the tight spots. It was a pain but I eventually got it on.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 02-26-2022, 05:36 PM
Antomero's Avatar
If you loosen the fan or remove the distributor rotor it will make your life easier. Ive done this job both with the fan on and off. With the fan on you would need to bend the strap so that it passes a little bump on the engine case. You could use a long thin screw driver to help guide the strap over the bump. If you remove or loosen the fan you will be able to see much clearer on how to guide the strap loose. Good luck!
Old 02-26-2022, 05:46 PM
Kind of Blue
MrBonus's Avatar
I ended up removing the fan from the shroud until I could wiggle it through. Thanks, all!
What an unexpectedly difficult job.
Old 02-27-2022, 10:30 AM
proporsche's Avatar
well? if you would removed the distributor and the oil press.sending unit(as John W.suggest) it will be done in 10 minutes..piece of cake...
Ivan
glad you made it thou;-)
1985 911 with original 502 191 miles...808 198 km
Old 02-27-2022, 10:40 AM
Kind of Blue
MrBonus's Avatar
Ivan
I spent most of my time trying to force it through under the housing. Had I cut it to begin with, it would have been a quick job.
At least I learned something from the process.
Old 02-27-2022, 11:01 AM
proporsche's Avatar
yup, no big deal we all learn about this beasts every day, even pro`s ;-)
Engine looks good...
Ivan
Old 02-27-2022, 11:27 AM
proporsche's Avatar
looking at your new strap ..those connecting pieces ,could be removed prior installing the strap? or you had to bolted it on the strap after you slide it through?
Ivan
Old 02-27-2022, 12:35 PM
Kind of Blue
MrBonus's Avatar
Ivan
Yes, the mounting brackets are secured by two screws. Just remove one side then feed it under. I used a pair of forceps to pull it underneath then remount the bracket. Super easy.
Old 02-27-2022, 12:58 PM
