aus911's Avatar
3.2 muffler
Hi All,
I have a 3.2 engine in my car with the standard exhaust.
I also have a sports muffler that fits and sounds great, it looks very similar to the standard muffler but without the recess for the Carrera heat tube .
So... I can only fit it without the Carrera heat tube fitted.
I would really like to modify my sports muffler to have the required recess for the Carrera heat tube.
Has anyone done this, if so how?
Cheers
Ray
Old 02-24-2022, 04:02 PM
cycling has-been
bkreigsr's Avatar
Yes.
Other than the recess for the crossover, they are identical.
Old 02-26-2022, 09:17 AM
aus911's Avatar
Ok, Thanks.
Has anyone modified their muffler to add the recess?
If yes, how?
Cheers
Old 02-26-2022, 01:38 PM
Sounds like your sports muffler was designed for an SC... I'd suggest contacting someone like Brian at Exhaust Innovations Capalaba... he might be able to cut a section to match your stock muffler.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 02-26-2022, 03:51 PM
aus911's Avatar
Hi Mike,
Thanks for the tip, I will contact him!!
BTW my engine and tranny is all ready for installation, now just waiting on an earth strap...
Cheers
Ray
Old 02-26-2022, 04:55 PM
You may to put floats on it!!
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 02-27-2022, 01:26 PM
