scca_ita's Avatar
How to tell if a spring plate is the desired adjustable ones?
Are there numbers identifying the ones that have more adjustablilty?
Old 05-20-2003, 07:50 PM
Super Moderator
cstreit's Avatar
You can tell just by looking. An adjustable spring plate is a two piece plate. Looks like this:
A non adjustable will be one solid metal plate all the way back.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 05-20-2003, 09:12 PM
Chuck Moreland's Avatar
Chris is showing an aftermarket Sway-a-way adjustable spring plate. More specifically, it's a G50 Sway-a-way.
The factory adjustable plates look like this:
Note the two large bolts near the pivot. Those are the adjusters.
Non adjustables lack those bolts.
Chuck Moreland - elephantracing.com - vonnen.com
Old 05-20-2003, 09:25 PM
Super Moderator
cstreit's Avatar
Oh, oops... Chuck, Did the factory ever make a plate that wasn't adjustable that way?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 05-20-2003, 09:41 PM
I'm partial to the factory adjustables. They provide adequate range, probably 1.5 inches total.
The sway-a-ways are heavy and the design is clunky.
To each his own.
Chris, yes the factory plates before '76 (I think) lacked those adjusters.
Old 05-20-2003, 09:46 PM
