What is this? Engine bay in SC
What are the two items circled? I'm assuming one is a smog bracket of some sort but what about the small thing near the engine mount? I'm trying to remove the bracket and the small round thing is in the way.
1979 911 SC Gran Prix White. Gone but not forgotten.
2016 GT4, current steed.
IG @hulley31
Old 03-01-2022, 03:22 PM
walt's Avatar
Air pump for smog control. Most people delete.
Walt
82SC 3.0
81SC 3.6
Old 03-01-2022, 03:45 PM
So can i pull out the round thing?
Old 03-01-2022, 03:51 PM
You can but you need to plug that hose/pipe because it will make exhaust leak noise
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-01-2022, 04:06 PM
Or you can get an Air Pump and make it right. It doesn't impede the performance at all. Got cars with and without and no performance difference.
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 03-01-2022, 04:45 PM
When you remove the round check valve an exhaust leak will be created. Most people remove the spaghetti air injection tube along with the valve and plug the ports at the head.
Porsche Air Injection Smog Pump Port Plug with washer, sold individually
Old 03-01-2022, 05:19 PM
MichaelSJackson's Avatar
And plug the hole remaining in the tin, once the "round thing" is removed. Jeez I let a lot of road grime into the engine compartment!
Old 03-01-2022, 06:11 PM
And exhuast heat sucked up into the motor!
Old 03-01-2022, 07:19 PM
What did you plug it with? Ive got the hole in my tins and a surprising amount of debris comes up.
Old 03-01-2022, 07:55 PM
Mark Salvetti's Avatar
I riveted an aluminum plate over mine. You can also try an expansion plug.
Mark
1979 911SC Targa
Old 03-01-2022, 10:21 PM
I didn't realize it was a check valve until this thread. lol
IG @hulley31
Old 03-02-2022, 04:29 AM
AlKid,
I also used 3 rivets to place a little aluminum below the hole.
MJ
Old 03-02-2022, 11:41 AM
Thanks for the link, I checked underneath and the air injection tube is still in place.
IG @hulley31
Old 03-02-2022, 12:19 PM
The problem is if you want to remove the injection tubes intact, you have to remove the heat exchangers and risk snapping exhaust studs. If you don't care to save the tubes, you can cut them. They are surprisingly easy to unscrew from the heads.
Mark
1979 911SC Targa
Old 03-02-2022, 07:29 PM
