chrisp's Avatar
Would you ever let a shop use the rear sway bar mount as a lifting point?
I rolled my car into a shop and they swore up and down that the rear sway bar mount was the best place to put a lift pad under the rear of a 911. They don't see 911's often. I recommended they put it just foward of the torsion bar tube area... the same place where the usual P-car shops put it.
Just thought I would check with you guys to see if anyone has had a bad experience lifting from there.
Old 05-20-2003, 06:53 AM
makaio's Avatar
I wouldn't, just because it's a PITA to replace one if it breaks.
Old 05-20-2003, 06:57 AM
just ahead of the mount.
206 637 4071
Old 05-20-2003, 07:20 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Good god no. Just ahead is better cause if my memory serves right, part of the chassis runs right there.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 05-20-2003, 07:24 AM
Uh, yeah, there or if they only have one lifting point in the rear they should use a chisel point wedged between the case halves.
It's amazing isn't it, you just have to wonder about people in shops sometimes...
Old 05-20-2003, 07:33 AM
Rick Lee's Avatar
Those mounts are a Porsche-specific weak spot to begin with. Why would anyone put anymore stress on them? NUTS!
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-20-2003, 07:42 AM
PCA7GGR's Avatar
For pre-87s, ust in front along the seam of the tub. This holds true for the front as well. Late year Carreras and newer had built-in jackpads.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 05-20-2003, 08:22 AM
Certified Pre-Owned
BGCarrera32's Avatar
Why not right under the floor pan at each corner? Then you can drive home and pound it all back flat with a big rubber mallet, busting off all the sound deadening material like I did...
'84 Carrera Coupe
Old 05-20-2003, 11:48 AM
