Dizzy mismatch?
Helping a friend with a 77 turbo engine. Can a 79 3.0 dizzy fit in a 77 turbo? Dizzy is a 0 237 301 001
Thanks in advance
Old 03-16-2022, 06:54 AM
yes the 3.0 will fit . the best answer is to drop a 123 bluetooth distributor in the engine .
It is very important to be able to set the timing advance and retard as the boost comes in
If you do not manage the boost it will work but not up to it's potential, idle will be tough as well
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 03-16-2022, 07:07 AM
No, I think they turn different directions, 77 clockwise, 79 counter clockwise. ??
Old 03-16-2022, 07:47 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Originally Posted by inaminit View Post
Thanks in advance
I see what you did there!
The 3.0 turbo engine as well as the 3.0 Carrera uses the 2.7L crankshaft which spins the distributor CLOCKWISE.
The 911SC 3.0 turns the distributor COUNTER-CLOCKWISE.
You unfortunately can't use this distro in your buddies 77 turbo 3.0 motor.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 03-16-2022, 07:50 AM
You need to change or convert the SC CCW distributor drive gear to CW rotation.
Tony
Old 03-16-2022, 08:11 AM
I'm looking for a 3.0 SC distributor, if you want to sell that one.
Old 03-16-2022, 08:17 AM
Thanks all! If a 3.0 spins backwards, wouldn’t that affect the advance mechanism?
Old 03-16-2022, 09:25 AM
Would you need to change the gear on the crankshaft to match the distributor drive gear cw rotation?
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 03-16-2022, 12:56 PM
sorry for my mistake , I just did an 87 turbo engine at 3.3 , in this engine the 3.0 sc distributor works
I hope this clears things up
Ian
Old 03-16-2022, 06:09 PM
