Power Window Operation Without Power
So I'm in the process of disassembling my SC for paint and I got myself in a bind. The door frames and glass need to come out but the power is already disconnected from the car and window motors. Any way to get the windows up and down without reconnecting everything? I hate those damned connections on the power window switch.
1982 911SC
Old 03-14-2022, 03:40 PM
Full Send Society
Jump the connections with a battery?
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 03-14-2022, 04:19 PM
Power and ground from your jumper battery to the two center wires that went to the switch from the motor. One way goes up, and other goes down.
206 637 4071
Old 03-14-2022, 04:40 PM
Booo
Well I was hoping there was a disconnect for the motor but that's life. Thanks.
1982 911SC
Old 03-15-2022, 06:31 AM
You can remove the motor from each side (3 screws) then you should be able to move the regulator and get the glass out.
Old 03-15-2022, 06:42 AM
This worked a treat, thanks. So long as I was mindful of the regulator not to pinch the cables and wires I was able to rotate the whole assembly to bring the window up and down enough to get the window frame out.
1982 911SC
Old 03-15-2022, 11:00 AM
Great! Glad it worked. Now keep the Pelican thread on the window switch wiring as you are going to need that at some point. I just installed power windows in my 1973 911T and used that post to wire my switches. cheers, Greg
Old 03-15-2022, 11:03 AM
Oh I have a bunch of photos of the wiring for those plugs, I hate those damned plugs.
1982 911SC
Old 03-16-2022, 05:43 AM
famoroso's Avatar
I got tired of the power window switch wiring decades ago. A pack of multicolor metallic Sharpies later, this seems like the easiest solution...
Frank Amoroso
911 M491 / M470 coupes:
1987 GP Wht / Blk "Apollo"
1987 Gemini Blue / Blk "Gemini"
1989 GP Wht / Blk "Vents"
Old 03-18-2022, 04:47 AM
That's pretty clever, I like it.
1982 911SC
Old 03-18-2022, 05:44 AM
Yes, I agree. Now what we need is someone to tell us how to convert from 5 pin window switches to the old style 4 pin switches with the chrome bezels. The chrome bezel switches look sharp in a back-date or older 911.
Old 03-18-2022, 07:24 AM
echecsqueen's Avatar
Love this idea. Thanks !!
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 02-16-2023, 03:59 PM
fallingat120mph's Avatar
Older thread but glad I caught this...have 1000 photos of different repairs and this takes some of that out of the equation.
1986 911 Coupe
1986 911 Targa
Old 02-16-2023, 09:31 PM
famoroso's Avatar
I'm glad Pelican's are finding my tip helpful.
Ironically enough, I've since converted to manual windows on the '89 from the above photos.
Frank Amoroso
Old 02-17-2023, 08:33 PM
Great idea. Sometimes the simplest solution is the best.
Old 02-18-2023, 10:08 AM
